Recipe for nodejs 18 on Maaxboard
inglevinay
I am trying to install nodejs 18 on Yocto (zeus) for Maaxboard. Is there a recipe available for Nodejs that works on zeus?
Imx8m
Sanket_Parekh
Hello @inglevinay ,
I hope you are doing well.
->One can add a layer to an image by adding the following line to the conf/local.conf file inside the build directory:
IMAGE_INSTALL_append = “ nodejs”
I hope it helps!
Thanks & Regards,
Sanket Parekh
inglevinay
Thank you for the response. Doing what you suggest installs Nodejs 10. Although, I want to install 18. I tried migrating poky/master but doing that gives an error.
Sanket_Parekh
Hi @inglevinay ,
Yocto Zeus (openEmbedded ) only supports nodejs 10.16 version.
It is not recommended to make any changes in the poky directory.
Thanks & Regards,
Sanket Parekh
