Reading the NOR flash data by MFG tool.
keitanagashima
Senior Contributor I
Dear Sir or Madam,
I'd like to read the data which is written in NOR FLASH and transfer the data to own PC.
Refer to following xml file.
ucl2.xml file;
<CMD state="Updater" type="push" body="$ dd if=/dev/mtdblock0 of=NorImage">read NorFlash</CMD>
<CMD state="Updater" type="push" body="read NorImage" file="OutPutNor">receiving NorImage</CMD>
<CMD state="Updater" type="push" body="$ echo Update Complete!">Done</CMD>
Line 1 looks successful that it write the contents of NOR Flash to "NorImage" file on Linux file system.
But, Line 2 looks fail (Transfer the "NorImage" file to PC).
Does anyone find this issue?
Keita
Labels (4)
YixingKong
Senior Contributor IV
Keita
Response from R&D:
Read function just support below 64k file size
jimmychan
Please see this for reference:
Re: MFG tool. Is it possible to read from flash
keitanagashima
Dear Jimmy,
I referred to your link.
But, there was only MFG tool for i.MX53.
The structure of MFG tool for i.MX6 and one for i.MX53 was different.
I found description of "pull" - Does UtpRead(body, file) transaction in ucl2.xml.
And, refer to the following code.
<LIST name="test" desc="for KM500">
    <CMD state="BootStrap" type="boot" body="BootStrap" file ="u-boot-mfg.bin" >Loading U-boot for KM500</CMD>
    <CMD state="BootStrap" type="load" file="uImage-mfg" address="0x10800000"
        loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Kernel.</CMD>
    <CMD state="BootStrap" type="load" file="initramfs.cpio.gz.uboot" address="0x10C00000"
        loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Initramfs.</CMD>
    <CMD state="BootStrap" type="jump" > Jumping to OS image. </CMD>
    <CMD state="Updater" type="push" body="$ dd if=/dev/mtdblock0 of=NorFile.bin">read nor</CMD>
    <CMD state="Updater" type="push" body="read NorFile.bin" savedfile="NorFile.bin">Getting uboot bin</CMD>
</LIST>
[Result]
The contents of NOR FLASH could save.
But, it couldn't read the data which is written in NOR FLASH and transfer the data to own PC.
[Question]
Could you tell me the way of adding a pull feature to ucl2.xml?
Or, give me some information.
Keita
israelpz
Hi Keita,
Maybe is going to sound silly but did you try to use a absolute path instead of a relative?
I going to test it today in order to check if the read command had a issue.
-Israel.
keitanagashima
Dear Israel,
Hello.
Do you have any update?
Keita
israelpz
Keita San,
Sorry for the delay. I already test it 5 times and seem this feature is not working as you mention.
I going to report this to R&D in order to fix this issue.
-Israel.
keitanagashima
Dear Israel,
I appreciate for your support.
OK. I wait the R&D's answer.
Keita
karina_valencia
NXP Apps Support
NXP Apps Support
From R&D:
keitanagashima
Dear Karina,
Thank you for your reply.
> From R&D:
I understood this limitation.
But, I have additional questions.
[Q1]
When transferring within 64 KB, following CMD format right?
</LIST>
[Q2]
Could you show me the general specified example of CMD?
[Q3]
The source code of MFG Tool is published.
If modifying the source code, is it possible to exceed 64 KB limitation?
Keita
karina_valencia
NXP Apps Support
NXP Apps Support
AlejandroSierra can you continue with the  follow up?
keitanagashima
Could someone follow up the question?
Keita
YixingKong
Keita
Response from R&D:
karina_valencia
NXP Apps Support
NXP Apps Support
AlejandroSierra do you have an update?
