Random reboot observed with imx6 3.14 linux kernel
1,565件の閲覧回数
atreyamit
Random reboot observed with imx6 3.14 linux kernel, custom board based on wandboard, any help shall be useful. full logs attached.
[2018-05-29 16:08:31] Device status command received
[2018-05-29 16:08:31] Stream URL: [all]
[2018-05-29 16:08:31] strcmp sucess for All module
[2018-05-29 16:08:31] sent sigusr2 to connmand
[2018-05-29 16:08:31] check Nwapp
[2018-05-29 16:08:31] buffer received is 68
[2018-05-29 16:08:31] LCD Event is updating
[2018-05-29 16:08:31] [AccessServiceApp] Access Message Type = 107
[2018-05-29 16:08:31] [Access Service App] [send registration status]:Sent data on StatusQueue
[2018-05-29 16:08:31] message received in statusmonitor
[2018-05-29 16:08:31] message Receive in sttaus response VOIP
[2018-05-29 16:08:31] message send all from rabbit-mq client
[2018-05-29 16:08:31] ......Before calling amqp_maybe_release_buffers........
[2018-05-29 16:08:31] .........Calling amqp_consume_message..........
[2018-05-29 16:08:31] [LCDManager] Received Message D
[2018-05-29 16:08:31] [LCDManager] bytes_read >= 0: Resource temporarily unavailable
[2018-05-29 16:08:31] type - 107
[2018-05-29 16:08:31] all n/wapp request process
[2018-05-29 16:08:31] [NwNotify-app][CELL] [NwNotifyThread]:Sent data allstatus cell on Intermediate app
[2018-05-29 16:08:31] message Receive in status response cell
[2018-05-29 16:08:31] [NwNotify-app][Wifi] [NwNotifyThread]:Sent data allstatus wifi on Intermediate app
[2018-05-29 16:08:31] message Receive in sttaus response wifi
[2018-05-29 16:08:31] [NwNotify-app] [Eth] [NwNotifyThread]:Sent data allstatus Ethernet on Intermediate app
[2018-05-29 16:08:31] message Receive in sttaus response ethernet
[2018-05-29 16:08:33] [NwNotify-app] [Eth] [AllstatusThread]:Sent data on EventQueue
[2018-05-29 16:08:34] Debug: Message with token value 146 delivery confirmed
[2018-05-29 16:08:34] entry nfc all
[2018-05-29 16:08:34] Invalid File
[2018-05-29 16:08:34] nfc details:
[2018-05-29 16:08:34] eventid=410
[2018-05-29 16:08:34] Timestamp=4294967295
[2018-05-29 16:08:34] Status = 0
[2018-05-29 16:08:35] Debug: Message with token value 147 delivery confirmed
[2018-05-29 16:08:35] Debug: Message with token value 148 delivery confirmed
[2018-05-29 16:08:42] Debug: Message with token value 149 delivery confirmed
[2018-05-29 16:08:50] Debug: Message with token value 150 delivery confirmed
[2018-05-29 16:08:50] Debug: Message with token value 151 delivery confirmed
[2018-05-29 16:08:58] Debug: Message with token value 152 delivery confirmed
[2018-05-29 16:09:05] Debug: Message with token value 153 delivery confirmed
[2018-05-29 16:09:05] Debug: Message with token value 154 delivery confirmed
[2018-05-29 16:09:13] Debug: Message with token value 155 delivery confirmed
[2018-05-29 16:09:13] Debug: Message with token value 156 delivery confirmed
[2018-05-29 16:09:21] Debug: Message with token value 157 delivery confirmed
[2018-05-29 16:09:28] Debug: Message with token value 158 delivery confirmed
[2018-05-29 16:09:28] Debug: Message with token value 159 delivery confirmed
[2018-05-29 16:09:36] Debug: Message with token value 160 delivery confirmed
[2018-05-29 16:09:43] Debug: Message with token value 161 delivery confirmed
[2018-05-29 16:09:44] Debug: Message with token value 162 delivery confirmed
[2018-05-29 16:09:51] Debug: Message with token value 163 delivery confirmed
[2018-05-29 16:09:52] WD Manager Initialization sucessfull
[2018-05-29 16:09:58] Debug: Message with token value 164 delivery confirmed
[2018-05-29 16:09:59] Debug: Message with token value 165 delivery confirmed
[2018-05-29 16:10:03]
U-Boot eliuaccs-1.0.3 (May 05 2018 - 01:10:24)
CPU: Freescale i.MX6SOLO rev1.3 996 MHz (running at 792 MHz)
Reset cause: WDOG [2018-05-29 16:10:03]
Board: eliu_accs [2018-05-29 16:10:03]
I2C: ready [2018-05-29 16:10:03]
DRAM: 512 MiB018-05-29 16:10:03]
MMC: USDHC4 Clock: 0x19800000003]
FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2-05-29 16:10:03]
board_mmc_getcd; USDHC3_BASE_ADDR [2018-05-29 16:10:03]
No panel detected: default to HDMI[2018-05-29 16:10:03]
Display: HDMI (1024x768) [2018-05-29 16:10:03]
1,435件の閲覧回数
Bio_TICFSL
Hi Amit,
You need to program it again, and if see it is booting, is the problem persist try it with another nfc, it said that invalid file.
