HI @TomC818!
Thank you for contacting NXP Support!
You have to ensure that the pins that you are using are configured to SDIO bus in device tree.
After that ensure that the fw and drivers are available for the wifi chip that you want to use.
The Linux that we use is the next: https://github.com/nxp-imx/linux-imx,by default is not supported, we only support our wifi chips in our BSP.
If you have more inquiries about the integrations of this wifi module you should consult to your wifi vendor.
Best Regards!
Chavira
