RTC issue-pca8565
RTC issue-pca8565
8,367 次查看
zhaocq
we use external RTC PCA8565, the bellow issues please help to resolve:
1) boot stage,we find the error log
[ 0.118882] rtc-pca8565 2-0051: Power loss detected, invalid time
[ 0.118987] rtc-pca8565 2-0051: rtc core: registered rtc-pca8565 as rtc0
[ 0.119585] rtc-pca8565 2-0051: Power loss detected, invalid time
[ 0.119591] rtc-pca8565 2-0051: hctosys: unable to read the hardware clock
2) after boot, we use command:i2cget -f -y 2 0x51 0x02
we can get the data(no i2c error), but the register 0x02 the highest bit is 1 always.
Could you tell me that is why, thanks in advance!
5 回复数
6,223 次查看
ekim
Do you have solved this issue on your side? If so, could you share how to fix it?
Thanks.
6,210 次查看
ekim
Does it mean should clear OS flag again to fix it?
6,685 次查看
jkl
Hello, could you please tell me whether this problem has been solved? I am also facing this problem now. I hope you can give me some advice, thank you very much
8,254 次查看
igorpadykov
Hi zhao
for power loss issue one can check hardware using documentation below:
PCA8565 datasheet
https://www.nxp.com/docs/en/data-sheet/PCA8565.pdf
User Manual
https://www.nxp.com/docs/en/user-guide/UM10301.pdf
software patch
rtc: add support for rtc NXP pca8565 - Patchwork
8,255 次查看
zhaocq
hi igor,
Thanks for your reply.
we have measure our power voltage and clk, they are both no problem. Also our i2c is ok.
but the register values sometimes report error, for example , the register 0x07 stands for month value,
we get the value is 0(1~12 reasonable).
I want to know before using pca8565_rtc_read_time, if i should set the time firstly, using pca8565_rtc_set_time?
Now we can not see pca8565_rtc_set_time call when reboot.
