RT685 FIR
RT685 FIR
insert
Hi all!
I want to make a filter for 10,000 taps for each of the 8 audio channels 48000(sample rate) on this processor. I can't find an example of a FIR filter for him.
1. How can I better store the FP32 coefficients in memory (10000taps*4byte*8cahnnels)so that the Cortex M33 is not a bottleneck in the system?
2. Is there enough CPU power for such a task?
Hui_Ma
RT600 is combining a high-performance Cadence® Tensilica® HiFi 4 audio DSP core .
DSP core has advantage for data processsing vs. ARM Cortex-M33 core, which includes finite impulse response (FIR).
I would recommend customer to refer and download Cadence HIFI DSP software development toolchain from here.
Wish it helps.
Mike
