RT1176 use MCU boot utility udpate FW by UART (baudrate support).
1,311 次查看
StephenYeh
Hi Sir,
We know that the update FW(serial download mode) via UART default is 115200 with RT1176.
Does it possiable that support up to 921600 bps
1,271 次查看
Pavel_Hernandez
Sorry but in the information does not have much information about this part. I do some test, in the first connection only show the 115200, I connect a RT1010 that I had available, the I open the combobox and show me more than one baudrate.
GitHub - JayHeng/NXP-MCUBootUtility: A one-stop boot utility tool based on Python2.7+wxPython4.0, it...
  • [Port Setup]: In the serial interface setting field, select the interface for connecting to the MCU Device.
Pavel
1,289 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get into your case and when I have more information, I will contact you.
Pavel
