RT1176 Qbv scheduling sequence
1,150 次查看
anjun
Hi, I have a problem right now and I need support
When I tested Qbv on RT1176, I found the following problems:
My GCL configuration list is Q0-100us, Q1-200us, Q2-300uS, Q3-400uS.
However, when BaseTime is set to 0, the scheduling order of Qbv is Q3->.Q2->Q1->Q0......... Q3->Q2->Q1->Q0.
However, when the baseTime configuration is greater than 0, the scheduling order of Qbv is Q0->Q1->Q2->Q3......... Q0->Q1->Q2->Q3.
The scheduling order is reversed.
Please confirm if this is the case.
标记 (1)
1,134 次查看
EdwinHz
Hi @anjun ,
I believe this question is repeated, please take a look to the response from the following community post:
https://community.nxp.com/t5/i-MX-RT/RT1176-Qbv-scheduling-sequence/td-p/1489179
BR,
Edwin.
