RT1064 Migrating UVC
2,531件の閲覧回数
徐芳泽
I want to port uvc to RT1064 following the RT1050 documentation tutorial. I followed every step of the tutorial, but after compiling and running it does not show any UVC device. Is there anything else I need to change? I am also using the MT9M114 camera and the following is my project.
Hello (NXP support in particular),
I am trying to use the latest (to date) SDK samples provided by NXP to stream video out of a MIMXRT1064 EVAL (a combination of the examples "video virtual camera" and "csi_rgb565"),  I followed every step of the tutorial,
Migrating AN12103 to EVKB-MIMXRT1050 with MCUXpres... - NXP Community
But after compiling and running it does not show any UVC device. Is there anything else I need to change? I am also using the MT9M114 camera and the following is my project.
Can someone please have a look and tell me why I cannot reach 30 FPS and what needs to happen to get there?
Thanks in advance!
4 返答(返信)
2,515件の閲覧回数
CarlosGarabito
Hi @徐芳泽 , here is an other AN that can help you, https://www.nxp.com/docs/en/application-note/AN12110.pdf, but you can try to use the example in SDK and works with that example.
2,507件の閲覧回数
徐芳泽
I gave up using RT1064 for the UVC port. I am now using RT1050EVK for UVC and after I followed this tutorial,
https://community.nxp.com/t5/i-MX-RT-Knowledge-Base/Migrating-AN12103-to-EVKB-MIMXRT1050-with-MCUXpr...
This project still does not work properly, does not show any uPVC camera device, I am using EVKB1050, SDK version 2.12.1, MT9M114 camera, project as attached
where I single-step debugging found this sentence in main.c can not be executed:
SEMC->SDRAMCR3 |= SEMC_SDRAMCR3_REN_MASK;
after i delete this sentence, this sentence in void InitCamera() can not be executed:
memset(s_cameraFrameBuffer, 0, sizeof(s_cameraFrameBuffer));
Could you please tell me, is there something wrong in my porting or what parameters need to be changed?
Also, I downloaded the uvc_demo provided under this tutorial, but he can't compile it, please tell me how to fix it. Thank you very much for your patience and help!
2,501件の閲覧回数
徐芳泽
补充一下,memset会跑到这然后不行了
2,499件の閲覧回数
徐芳泽
这是我的硬件,请问我有什么是需要改动的吗?或者,我的软件是否与我的硬件适配?比如在SDRAM方面
