RT1062 implement to support TLS1.2. (based on the MbedTLS sample code)
StephenYeh
Hi Sir,
If our customer needs support TLS 1.2 or 1.3 based on RT1062(AES128 only).
Is it possiable?
Or, They needs design change RT1062 + SE050,
or change platform to RT116x
or RT1062 + FW AES256 (Merge it to Mbed)) etc..?
StephenYeh
Hi Kerry
Thank for your support.
If customer want to support TLS1.2 or above version, does the RT1170 support or not?
kerryzhou
Hi @StephenYeh ,
  Maybe you need to find the source code and port it to the SDK  by yourself if you need above TSL1.2 version. As I know, internal side, still don't have higher version.
Kerry
kerryzhou
Hi @StephenYeh ,
   Thanks so much for your cooperation with the new questions post. Welcome!
    As I know,  TLS 1.2 with RT1062  and AES128 can be supported.
You can refer to the RT1060 SDK demo:
\SDK_2_13_1_EVK-MIMXRT1060\boards\evkmimxrt1060\lwip_examples\lwip_httpssrv_mbedTLS
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
StephenYeh
Hi Jeremy
If customer want to support TLS1.2  (SHA384 & AES256), they needs upgrate to RT11xx series, right?
kerryzhou
Hi @StephenYeh ,
   I am Kerry, Jeremy already leave NXP, thanks.
  RT1170 can support AES256, sha384, but RT106X can't support SHA384
Kerry
