RT1062 SAI EDMA Using Same Callback For both TX & RX?
vincentmokrc
It is possible for us to use only one callback for EDMA TX and RX? Currently the callbacks for SAI EDMA callback is separated into two callbacks.
Tags (4)
Gavin_Jia
Hi @vincentmokrc ,
Thanks for your interest in NXP MIMXRT series!
Yes, you can do this. Tx and Rx can be decoupled by using the passed *userData. e.g. when creating SAI EDMA handles, pass in different userData for TX and RX respectively, such as the addresses of txHandle and rxHandle.
Gavin
