RT1046 DCP kDCP_OtpUniqueKey not working
791 次查看
ScottW_7
Hi NXP team,
        I used the RT1046 as the encryption operation unit for DCP, setting GPR10 to use the key from OCOTP (SW_GP2), and then programmed the key(sw_key) into SW_GP2.
        During testing, I found that the data encrypted with AES_ECB using kDCP_OtpKey and kDCP_OtpUniqueKey are identical, they also match the result when I directly use sw_key for AES_ECB encryption.
        According to the Reference Manual, kDCP_OtpUniqueKey should be independent and not the same as kDCP_OtpKey. Why is this happening?
751 次查看
Bio_TICFSL
The difference between kDCP_OtpKey and kDCP_OtpUniqueKey relates to how these keys are derived:
1. kDCP_OtpKey corresponds to the SW_GP2 key that you've programmed into the OCOTP fuses.
2. kDCP_OtpUniqueKey should be a device-unique key derived from the OTPMK (On-Time Programmable Master Key) and should produce different results than kDCP_OtpKey.
The reason you're seeing identical results is likely because your device is operating in an "open" (non-secure) configuration. In this configuration, the DCP doesn't generate true unique keys but instead uses standard values that may be identical across devices.
For kDCP_OtpUniqueKey to produce truly unique results different from kDCP_OtpKey, your RT1046 would need to be configured in a "secure closed" mode, where the OTPMK is properly utilized to create device-specific unique keys.
To verify this, check if you have properly configured the security settings, particularly SEC_CONFIG bits related to the OTPMK. Without proper security configuration, both key options will effectively use the same SW_GP2 value you programmed.
%3CLINGO-SUB%20id%3D%22lingo-sub-2255890%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT1046%20DCP%20kDCP_OtpUniqueKey%20%E6%97%A0%E6%B3%95%E5%B7%A5%E4%BD%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255890%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CNXP%E5%9B%A2%E9%98%9F%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%3CSPAN%3E%E6%88%91%E4%BD%BF%E7%94%A8%20RT1046%20%E4%BD%9C%E4%B8%BA%20DCP%20%E7%9A%84%E5%8A%A0%E5%AF%86%E6%93%8D%E4%BD%9C%E5%8D%95%E5%85%83%EF%BC%8C%E5%B0%86%20GPR10%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%BD%BF%E7%94%A8%20OCOTP%20%E7%9A%84%E5%AF%86%E9%92%A5%EF%BC%88SW_GP2%EF%BC%89%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%E5%AF%86%E9%92%A5%EF%BC%88sw_key%EF%BC%89%E7%BC%96%E5%85%A5%20SW_GP2%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%E5%9C%A8%E6%B5%8B%E8%AF%95%E8%BF%87%E7%A8%8B%E4%B8%AD%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E4%BD%BF%E7%94%A8%20kDCP_OtpKey%20%E5%92%8C%20kDCP_OtpUniqueKey%20%E8%BF%9B%E8%A1%8C%20AES_ECB%20%E5%8A%A0%E5%AF%86%E7%9A%84%E6%95%B0%E6%8D%AE%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%EF%BC%8C%E5%AE%83%E4%BB%AC%E4%B9%9F%E4%B8%8E%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%20sw_key%20%E8%BF%9B%E8%A1%8C%20AES_ECB%20%E5%8A%A0%E5%AF%86%E6%97%B6%E7%9A%84%E7%BB%93%E6%9E%9C%E4%B8%80%E8%87%B4%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%A0%B9%E6%8D%AE%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%8CKDCP_OTPuniqueKey%20%E5%BA%94%E8%AF%A5%E6%98%AF%E7%8B%AC%E7%AB%8B%E7%9A%84%EF%BC%8C%E4%B8%8E%20KDCP_OTPKey%20%E4%B8%8D%E4%B8%80%E6%A0%B7%E3%80%82%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E8%BF%99%E6%A0%B7%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2255890%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1046%20DCP%20kDCP_OtpUniqueKey%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CDIV%20class%3D%22container%20slds-m-bottom_x-small%22%3E%0A%3CP%3EkDCP_OtpKey%20%E5%92%8C%20kDCP_OtpUniqueKey%20%E4%B9%8B%E9%97%B4%E7%9A%84%E5%8C%BA%E5%88%AB%E4%B8%8E%E8%BF%99%E4%BA%9B%E5%AF%86%E9%92%A5%E7%9A%84%E6%B4%BE%E7%94%9F%E6%96%B9%E5%BC%8F%E6%9C%89%E5%85%B3%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E1.%20kDCP_OtpKey%20%E5%AF%B9%E5%BA%94%E4%BA%8E%E4%BD%A0%E5%9C%A8%20OCOTP%20%E7%86%94%E4%B8%9D%E4%B8%AD%E7%BC%96%E7%A8%8B%E7%9A%84%20SW_GP2%20%E5%AF%86%E9%92%A5%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E2.%20kDCP_OtpUniqueKey%20%E5%BA%94%E6%98%AF%E6%BA%90%E8%87%AA%20OTPMK%EF%BC%88%E5%87%86%E6%97%B6%E5%8F%AF%E7%BC%96%E7%A8%8B%E4%B8%BB%E5%AF%86%E9%92%A5%EF%BC%89%E7%9A%84%E8%AE%BE%E5%A4%87%E5%94%AF%E4%B8%80%E5%AF%86%E9%92%A5%EF%BC%8C%E4%BA%A7%E7%94%9F%E7%9A%84%E7%BB%93%E6%9E%9C%E5%BA%94%E4%B8%8E%20kDCP_OtpKey%20%E4%B8%8D%E5%90%8C%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%A0%E7%9C%8B%E5%88%B0%E7%9B%B8%E5%90%8C%E7%BB%93%E6%9E%9C%E7%9A%84%E5%8E%9F%E5%9B%A0%E5%8F%AF%E8%83%BD%E6%98%AF%E5%9B%A0%E4%B8%BA%E4%BD%A0%E7%9A%84%E8%AE%BE%E5%A4%87%E5%9C%A8%20%22%20%E5%BC%80%E6%94%BE%20%22%EF%BC%88%E9%9D%9E%E5%AE%89%E5%85%A8%EF%BC%89%E9%85%8D%E7%BD%AE%E4%B8%8B%E8%BF%90%E8%A1%8C%E3%80%82%E5%9C%A8%E6%AD%A4%E9%85%8D%E7%BD%AE%E4%B8%AD%EF%BC%8CDCP%20%E4%B8%8D%E4%BC%9A%E7%94%9F%E6%88%90%E7%9C%9F%E6%AD%A3%E7%9A%84%E5%94%AF%E4%B8%80%E5%AF%86%E9%92%A5%EF%BC%8C%E8%80%8C%E6%98%AF%E4%BD%BF%E7%94%A8%E8%B7%A8%E8%AE%BE%E5%A4%87%E5%8F%AF%E8%83%BD%E7%9B%B8%E5%90%8C%E7%9A%84%E6%A0%87%E5%87%86%E5%80%BC%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%A6%81%E4%BD%BF%20Kdcp_otpuniqueKey%20%E4%BA%A7%E7%94%9F%E4%B8%8E%20KDCP_OTPKey%20%E4%B8%8D%E5%90%8C%E7%9A%84%E7%9C%9F%E6%AD%A3%E7%8B%AC%E7%89%B9%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%8C%E9%9C%80%E8%A6%81%E5%9C%A8%20%22%20%E5%AE%89%E5%85%A8%E5%B0%81%E9%97%AD%20%22%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%E9%85%8D%E7%BD%AE%20RT1046%EF%BC%8C%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%A8%A1%E5%BC%8F%E4%B8%8B%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%AD%A3%E7%A1%AE%E5%88%A9%E7%94%A8%20OTPMK%20%E6%9D%A5%E5%88%9B%E5%BB%BA%E8%AE%BE%E5%A4%87%E4%B8%93%E7%94%A8%E7%9A%84%E5%94%AF%E4%B8%80%E5%AF%86%E9%92%A5%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%A6%81%E9%AA%8C%E8%AF%81%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E8%AF%B7%E6%A3%80%E6%9F%A5%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E9%85%8D%E7%BD%AE%E4%BA%86%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%E4%B8%8E%20OTPMK%20%E7%9B%B8%E5%85%B3%E7%9A%84%20SEC_CONFIG%20%E4%BD%8D%E3%80%82%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E6%AD%A3%E7%A1%AE%E7%9A%84%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%EF%BC%8C%E8%BF%99%E4%B8%A4%E4%B8%AA%E5%AF%86%E9%92%A5%E9%80%89%E9%A1%B9%E5%B0%86%E6%9C%89%E6%95%88%E5%9C%B0%E4%BD%BF%E7%94%A8%E6%82%A8%E7%BC%96%E7%A8%8B%E7%9A%84%E7%9B%B8%E5%90%8C%E7%9A%84%20SW_GP2%20%E5%80%BC%E3%80%82%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CDIV%20data-render-key%3D%221%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22section%20slds-grid%20slds-gutters_direct%20slds-wrap%22%3E%0A%3CDIV%20data-render-key%3D%221%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22slds-grid%20slds-wrap%20slds-gutters_direct%22%3E%E6%AD%A4%E8%87%B4%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
