RPMsg performance Benchmark
9,021 次查看
jithesh77
RPMsg communication performance Benchmark is available for i.Mx8QXPlus between Cortex-A35 and M4 Cores .What will be the maximum communication speed we can achieve ?.
Jithesh
8,953 次查看
joanxie
I attached the test result which is based on i.MX8QXP C0 MEK board REV D4 with L5.4.3_2..0.0, hope helpful for you
5 回复数
8,943 次查看
jithesh77
Thanks for the support and Test results.
Jithesh
8,999 次查看
jithesh77
Could you please confirm on the RPMsg performance if somebody is familiar with RPMsg between Cortex-A35 and M4 Cores in i.Mx8QXPlus .
Thanks in Advance
Jithesh
8,954 次查看
joanxie
7,201 次查看
Majidbahmani
I would like to test RPMsg performance between Cortext-A53 and Cortex-M7 for IMX8M Plus. Is there any similar "RPMsg Performance Benchmark" for IMX8M Plus?
Thank you.
5,619 次查看
VishalGSawarkar
Its good to see that you took this test. If you have any data. Can you post here?
