RPMsg bypass
RPMsg bypass
1,925件の閲覧回数
greg_edwards
On the imx8mm is it possible to use shared memory between the A53s (Linux) and M4 (RTOS) without going through RPMsg?  I don't see any notes stating that it's not possible, but also no examples of doing it without RPMsg.
TIA
2 返答(返信)
1,811件の閲覧回数
kunalkotecha1
Senior Contributor II
Hi [email protected] ,
You can implement the shared memory between A53 and M4 on your own by sharing the DDR between them. However, RPMSG does the same. So, I would suggest rather than implementing it, you use the supported RPMSG.
Kunal
1,811件の閲覧回数
greg_edwards
Thx
