REg: Streaming and Recording Simultaneously
vishvapathi
Contributor V
Hi All,
I used the below command to record the video from a UVC CAM, it records. But the size is too large. How to add encoding to this??
gst-launch-0.10 v4l2src device=/dev/video0 ! video/x-raw-yuv,width=352,height=288 ! avimux ! filesink location=test0.avi
Below command i used for streaming a single CAM.. it works fine... How to so streaming and recording at same time... read in the abv link should add "tee".. can someone share any documents regarding this??
gst-launch v4l2src device=/dev/video0 ! video/x-raw-yuv,width=320,height=240 ! ffmpegcolorspace ! mfw_isink disp-width=450 disp-height=300  axis-left=50 axis-top=100
And for $gst-launch v4l2src num-buffers=-1 ! queue ! vpuenc codec=0 ! matroskamux ! filesink location=output.mkv sync=false
No such IOCTL, cmd is 22032
Setting pipeline to PAUSED ...
[INFO]  Product Info: i.MX6Q/D/S
vpuenc versions :smileyhappy:
        plugin: 3.0.7
        wrapper: 1.0.35(VPUWRAPPER_ARM_LINUX Build on Feb 14 2014 12:45:49)
        vpulib: 5.4.16
        firmware: 2.3.10.40778
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not negott
Additional debug info:
gstbasesrc.c(2787): gst_base_src_start (): /GstPipeline:pipeline0/GstV4l2Src:v4:
Check your filtered caps, if any
Setting pipeline to NULL ...
Freeing pipeline ...
I get the above ERROR
Any suggestions is appreciated!!!!!!!!!!!
DaianeAngolini
shanmugamsundar
Labels (3)
shanmugamsundar
try using this command
gst-launch mfw_v4lsrc fps-n=30 capture-width=640 capture-height=480 capture-mode=0  ! queue ! mfw_vpuencoder codec-type=0 ! avimux ! filesink location=shan3.avi sync=false
shan
vishvapathi
Contributor V
Hi Shan,
$ gst-launch mfw_v4lsrc fps-n=30 capture-width=640 capture-height=480 capture-mode=0  ! queue ! mfw_vpuencoder codec-type=0 ! avimux ! filesink location=shan3.avi sync=false
MFW_GST_V4LSRC_PLUGIN 3.0.7 build on Feb 14 2014 12:47:21.
WARNING: erroneous pipeline: no property "capture-width" in element "mfwgstv4ls"
I am getting the above warning...
shanmugamsundar
hi viswa,
    which multimedia codec version you are using is it 11.09 or ?
vishvapathi
Contributor V
$gst-inspect | grep mfw
mpeg2dec.imx:  mfw_mpeg2decoder: mpeg2 video decoder
h264.imx:  mfw_h264decoder: h264 video decoder
mpeg4dec.imx:  mfw_mpeg4aspdecoder: mpeg4 video decoder
amrdec.imx:  mfw_amrdecoder: amr audio decoder
mp3enc.imx:  mfw_mp3encoder: mp3 audio encoder
audiopeq.imx:  mfw_audio_pp: audio post equalizer
v4lsrc.imx:  mfw_v4lsrc: v4l2 based camera src
v4lsink.imx:  mfw_v4lsink: v4l2 video sink
isink.imx:  mfw_isink: IPU-based video sink
ipucsc.imx:  mfw_ipucsc: IPU-based video converter
I dont hav mfw_vpuencoder: mfw_vpuencoder: Freescale: Hardware (VPU) Encoder installed i guess!!!
Yuri
For i.MX6  codec prefix "mfw" is not used; elements re mnamed just as "vpudec", "vpuenc"
gst-inspect | grep imx
vishvapathi
Contributor V
Hi Yuri,
         I tried the below command...
$gst-launch v4l2src always-copy=false queue-size=16 num-buffers=900 ! queue ! capsfilter caps='video/x-raw-yuv,format=(fourcc)YUY2, width=640, height=480,framerate=30/1' ! ffmpegcolorspace ! capsfilter caps='video/x-raw-yuv,format=(fourcc)I420, width=640, height=480' ! vpuenc ! avimux! filesink location= /home/test.avi
RESPONSE ON SCREEN
        plugin: 3.0.7
        vpulib: 5.4.16
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
[INFO]  chromaInterleave 0, mapType 0, linear2TiledEnable 0
And the processor doesnt respond for any action....
Yuri
First, please try simplified  command :
$gst-launch v4l2src  ! ffmpegcolorspace !  vpuenc ! avimux! filesink location= /home/test.avi
then we can insert more details in order to define what option provides the problem.
vishvapathi
Contributor V
Hi Yuri,
   After issuing the above command the processor doesnt respond for any command or interrupt. It hangs/freezes
$ gst-launch v4l2src device=/dev/video1 ! ffmpegcolorspace !  vpuenc ! avimux! filesink location= /home/test.avi
        plugin: 3.0.7
        vpulib: 5.4.16
[INFO]  chromaInterleave 1, mapType 0, linear2TiledEnable 0
I have to restart manually to make it work again...
Yuri
In the beginning of the thread :
$ gst-launch v4l2src device=/dev/video0 ! video/x-raw-yuv,width=320,height=240 ! ffmpegcolorspace ! mfw_isink disp-width=450 disp-height=300  axis-left=50 axis-top=100
it is stated this works ? correct ?
vishvapathi
Contributor V
Yes... the below command works fine... its streams from the CAM...  until i giv ctrl+c...
$ gst-launch v4l2src device=/dev/video1 ! video/x-raw-yuv,width=320,height=240 ! ffmpegcolorspace ! mfw_isink disp-width=450 disp-height=300  axis-left=50 axis-top=100
MAX resolution 1024x768
set color key
MFW_GST_ISINK_PLUGIN 3.0.7 build on Feb 14 2014 12:47:47.
hwbuf allocator zone(155648) created
hwbuf allocator zone(155648) destroied.
can not create threadmfw_gst_isink_setcaps:1489
VS0 created. in fmt[YUYV] win(0,0-320,240:320x240) out win(50,100-500,400:450x300)
set deinterlace mode 0
vishvapathi
Contributor V
Hi Yuri,
The below command works..
gst-launch --eos-on-shutdown v4l2src device="/dev/video1" ! video/x-raw-yuv,width=640,height=480 ! ffmpegcolorspace ! jpegenc ! avimux ! filesink location=video.avi
For a 7 second video the size is 6.3MB. I am not sure whether the Encoding technique is actually happening..
Any Suggestions?
Yuri
  First, the GST element " jpegenc" relates to software implementation (via ARM core instructions,
without  VPU support). Obe can use the next element (mjpg - image/jpeg) : ! vpuenc  codec=12 !
  Next, MJPEG  provides separate frames encoding, without using correlations between frames,
therefore compression ratio is not so good as - say -  for H.264.
vishvapathi
Contributor V
My Device Hangs/Freezes for the below command
$ gst-launch v4l2src device=/dev/video1 ! ffmpegcolorspace !  vpuenc ! matroskamux ! filesink location= /home/test.mkv
        plugin: 3.0.7
        vpulib: 5.4.16
Can anyone give me pointers about why this issue is happening????
Tarek
vishvapathi
Contributor V
Hi All,
Attaching Log file...
partial log file...
Complete log file attached....
stat: /usr/lib/gvfsd (error: No such file or directory)
0:01:38.528375912  2747    0x17050 LOG       GST_PLUGIN_LOADING gstplugin.c:1651:gst_plugin_ext_dep_scan_path_with_filenames:<plugin8> stat: /qt/lib/gvfsd (error: No such file or directory)
0:01:38.528765246  2747    0x17050 LOG       GST_PLUGIN_LOADING gstplugin.c:1651:gst_plugin_ext_dep_scan_path_with_filenames:<plugin8> stat: /usr/local/lib/gvfsd (error: No such file or directory)
0:01:38.529151246  2747    0x17050 LOG       GST_PLUGIN_LOADING gstplugin.c:1651:gst_plugin_ext_dep_scan_path_with_filenames:<plugin8> stat: /home/vishva/Desktop/L3.0.35_4.1.0_130816_source/yes/ltib/rootfs/usr/lib/gvfsd (error: No such file or directory)
0:01:38.529432246  2747    0x17050 LOG       GST_PLUGIN_LOADING gstplugin.c:1710:gst_plugin_ext_dep_get_stat_hash:<plugin8> done, scan_hash:
And it stops after the below data....
0:03:39.782497926  2747    0xc7d70 INFO                  vpuenc vpuenc.c:1175:gst_vpuenc_chain: get vpuenc require 4 frames.
0:03:39.887960927  2747    0xc7d70 LOG                   vpuenc vpuenc.c:1205:gst_vpuenc_chain: chain in with inbuffer size = 1843
Yuri
I just tried the next command
$ gst-launch v4l2src device=/dev/video0 ! ffmpegcolorspace ! vpuenc ! matroskamux ! filesink location= /home/test.mkv
under the following environment :
- SDP board ;
- Linux L3_0_35_4_1_0 ;
- IMX_MMCODEC_3.0.35_4.1.0 codec package.
And the issue is not reprodusible.
What is different in Your system ?
vishvapathi
Contributor V
Hi Yuri,
       I have MARS board with IMX processor from Embest Technologies.
- Linux L3.0.35_4.1.0_130816
- Multi-media:IMX_MMCODEC_3.0.35_4.1.0_BUNDLE_CODA
I guess it is as same as your configuration.
vishvapathi
Contributor V
LeonardoSandovalGonzalez
For video from Webcam i am getting the following error...
$ gst-launch v4l2src device=/dev/video1 num-buffers=-1 ! queue ! vpuenc codec=0 ! matroskamux ! filesink location=output.mkv sync=false
        plugin: 3.0.7
        vpulib: 5.4.16
daiane_angolini
cool
let us know
daiane_angolini
1) how to set camera resolution:
You can see gst-inspect v4lsrc and look for the resolution parameters
Don´t forget to use the same for mux and encoder
2)
tee
GStreamer-devel - Good example to show usage of tee
