RE : Authenticating yocto rootfile system
3,320 次查看
khaleel
Hello
Currently i'm working on secure boot. I need to authenticate the rootfilesystem (yocto).
Please provide me, if any documentations/procedures available.
Thanks & Regards
khaleel
3,308 次查看
Hi khaleel
one can look at tutorial on
https://www.timesys.com/security/secure-boot-encrypted-data-storage/
Secure appnotes on below link, like AN12714 i.MX Encrypted Storage Using CAAM Secure Keys
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/i-mx-applications-proces...
4 回复数
3,309 次查看
Hi khaleel
3,294 次查看
khaleel
Hi igor,
Thank you very much for the documentation.
As of now i'm only trying to Authenticate rootfile sytem using dm-verity and i don't want to Encrypt it.
Mostly dm-verity is used in Android devices, As it is kernel’s device mapper module i believe it should support for linux device  too.
I didn't find a document implementing dm-verity to verify linux rootfile system. If you have a procedure please share with me.
Khaleel
2,716 次查看
imx8-mdt
@khaleel
have you implemented the dm-verity on linux ,rather than Android?
I face the same task as you.
Is there any documents to refer to?
3,281 次查看
Hi Khaleel
unfortunately I am not aware of other documents, except provided on above link.
