RD-IMX6Q-SABRE DCD Configuration
1,865 次查看
conor_syk
I'm looking for a reliable DCD configuration for DDR3 on the RD-IMX6Q-SABRE Board.
1,842 次查看
Sanket_Parekh
Hi @conor_syk
I hope you are doing well.
One can refer to /board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg for RD-IMX6Q-SABRE Board.
Alternatively, one can perform a DDR stress test using i.MX6DQ Register Programming Aids and generate .cfg file.
Thanks & Regards,
Sanket Parekh
1,843 次查看
Sanket_Parekh
Hi @conor_syk
Thanks & Regards,
Sanket Parekh
1,834 次查看
conor_syk
Thank you very much for the solution!
