HI ,
I have custom board with IMX6Uqad, using kernel version 4.9.123, recently we ran into rcd preempt CPU stall issue and kernel hangs, while running overnight, as part of debugging , I removed the non used Peripherals. I removed HDMI+GPu configuration, after removal , I didn't see the issue happening,
Is there an explanation , why removing GPU and HDMI , stopped the RCU preempt stalling.
Thanks and Regards
Terry
