Question, i.MX6ULL power-up/down sequence
1,588 次查看
Aemj
Dear team,
I would like to ask about power-up/down sequence of i.MX6ULL.
Do you have any timing chart describing the power-up/down sequence of i.MX6ULL?
And my customer cannot find any description about the timing for NVCC_DRAM and NVCC_xxxx in i.MX6ULL datasheet.
Could you show me the power-up/down timing for NVCC_DRAM and NVCC_xxxx in addition to VDD_SNVS_IN and VDD_HIGH_IN?
Miyamoto
1,382 次查看
Yuri
  According to the i.MX6ULL Datasheet(s) :
- VDD_SNVS_IN supply must be turned on before any other power supply ;
- VDD_HIGH_IN should be turned on before VDD_SOC_IN.
No more restrictions.
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
