Question, i.MX6SoloLite SD Card Interface
1,205 次查看
Aemj
Dear team,
I would like to ask about SPEED and SRE bit field setting of i.MX6SoloLite IOMUXC_SW_PAD_CTL_PAD_xxx register.
My customer is facing the issue that they sometimes saw CRC error on SD Card data transfer between i.MX6SoloLite. And they think SPPED and SRE setting of IOMUXC_SW_PAD_CTL_PAD_xxx registers might affect it.
(1)
What values should be set to SPEED bit field of IOMUXC_SW_PAD_CTL_PAD_xxx registers?
The customer is using SD Card interface of i.MX6SL as SDR-50.
(2)
What values should be set into SRE field of IOMUXC_SW_PAD_CTL_PAD_xxx registers for related pads? And could you show me what is changed actually by the setting of SRE bit?
Miyamoto
1,133 次查看
Yuri
  I hope app note AN5078 (Influence of Pin Setting on System Function
and Performance) clarifies the issue.
http://cache.freescale.com/files/32bit/doc/app_note/AN5078.pdf
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
