Question, how to read PCIE_DISABLE fuse value
已解决
跳至解决方案
2,731 次查看
Aemj
Dear team,
I would like to ask about how to read PCIE_DISABLE fuse status from i.MX6SX.
My customer is working on the issue which is similar to the one that is described in ERR009572. Though the chip’s date-code is 1525, the phenomenon still occur on their board. Because the issue is caused by PCIE_DISABLE fuse status, they want to read out the fuse status from the chip.
Could you show me how to read the PCIE_DISABLE value?
We could not find the location of PCIE_DISABLE in the fuse-map from your reference manual.
Miyamoto
标签 (1)
1 解答
2,619 次查看
Hi Miyamoto
please create service request, as this is confidential info:
How to create service request :
https://community.freescale.com/docs/DOC-329745
在原帖中查看解决方案
2 回复数
2,620 次查看
Hi Miyamoto
2,619 次查看
Aemj
Hello Igor,
OK!
You mean TIC's SR, right?
I will do.
Miyamoto
