Dear team,
I would like to ask about how to read PCIE_DISABLE fuse status from i.MX6SX.
My customer is working on the issue which is similar to the one that is described in ERR009572. Though the chip’s date-code is 1525, the phenomenon still occur on their board. Because the issue is caused by PCIE_DISABLE fuse status, they want to read out the fuse status from the chip.
Could you show me how to read the PCIE_DISABLE value?
We could not find the location of PCIE_DISABLE in the fuse-map from your reference manual.
Miyamoto
Solved! Go to Solution.
Hi Miyamoto
please create service request, as this is confidential info:
How to create service request :
https://community.freescale.com/docs/DOC-329745
Hi Miyamoto
Hello Igor,
OK!
You mean TIC's SR, right?
I will do.
Miyamoto
