Had anyone run weston extended mode for dual display successfully on iMX8MQ EVK?
Currently, I could only run weston on only one display (on drm/card0 or drm/card1) without extended mode support. It looks like the "[output] name" field is ignored by weston. It always uses "drm/card1" if I don't select card by "--drm-device=cardX" parameter.
