Qt5 segmentation fault with EGL
rakesh3
Contributor V
Hi team,
I am using the imx6qsabresd board with kernel version 5.10 and using the imx-gpu-viv_6.4.3 version vivante GPU.
I am getting the Segmentation fault while running the Qt5 GPU application.
As per the given link https://community.nxp.com/t5/i-MX-Processors/QT5-4-eglfs-hellogl-es2-Segmentation-fault/m-p/423948
I have the correct version of GPU vivante 6.4.3 with kerenel version 5.10
How to confirm about the correct user mode libraries imx-gpu-viv compatible for X11 display ?
From where i can get those libs ?
Please help me to solve this issue !
Rk
Labels (4)
Tags (2)
Bio_TICFSL
X11 don't work with 5.x kernel and up, you need to have 4.x kernel version.
rakesh3
Contributor V
Thanks for reply,
But we have received the prebuild libraries for GPU from NXP, I have attached the libs.
Please have a look into those libs and give your suggestions on this.
Rk
