Qt multi thread opengl demo run failed after break and restart in weston 1.5
xiongweihuang
Hello all
I follow the FSL Ycoto  project patched on weston 1.5 and make a runable Qt 5.3.1 + weston 1.5 enviroment
And on my test
After run weston with
# export FB_MULTI_BUFFER=2
# weston --tty=1 --use-gl=0 --use-gal2d=1 --idle-time=65536
And run
# ./hellowindow -platform wayland-egl ( This create 3 windows as default )
ctrl +c stop it and repeat the same command , seems weston get blocked ,and no error output . no black screen .
But
This error not occur when I test with
# ./hellowindow --single -platform wayland-egl, (This create one windows)
So , if you can reproduce it , can you fix with the weston patch ? or driver problem ?
Xiongwei
Labels (4)
