QSSLSocket on imx6 platform errors.
michaeldiamond
We have a project using LTIB and QT 4.8.4. It needs to send emails. We have tried a couple different clients and versions that use qsslsocket. The errors we are getting are the socket gets closed before we receive the connection is encrypted signal or if we wait using the socket->waitForEncrypted() method. We are not sure if it uses openssl, openssh, libssl or other external libraries that we might not have the correct version installed.
Both clients we try work when we use them in windows and ubuntu, but the cross compiled version we run on our target has the above issues.  the socket error we get is 13 which is the certificate is blank but that is because until the connection becomes encrypted the cert. is not available.  Anyone done something similar?
Labels (4)
YixingKong
Senior Contributor IV
Michael
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
YixingKong
Michael
We have not got your response yet and will close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
YixingKong
Michael
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow resolved the issue, can we close the discussion? If you still need help, please feel free to reply with an update to this discussion.
Yixing
