Hi all,
I am evaluating IMX8MQ evk board and linux Distro 4.14-ga release. I want to Set QSPI clock rate 100MHZ in fsl driver property. So, I have made some clock rate changes in fsl-imx8mq-evk.dts file as following.
&qspi {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_qspi>;
spi-max-frequency = <100000000>;
status = "okay";
flash0: w25q256@0 {
reg = <0>;
#address-cells = <1>;
#size-cells = <1>;
compatible = "sst,w25q256";
spi-nor,ddr-quad-read-dummy = <6>;
status = "okay";
But when i measuring clock at QSPI_SCLK pin it gives the 25Mhz.So, my query is
1. How to set QSPI CLOCK RATE 100Mhz?
2. Can you please suggest me modification to set?
Let me know if you need further information.
Darshak
