Python code
Python code
4,896 次查看
1990rahulreddy
How can I run Helloword.py, in YOCTO. I have qt image installed in SABRE-SDP.
Is there new ubuntu launch for i.MX6. I know older ubuntu(11. #).
标签 (3)
4,651 次查看
gusarambula
1990rahulreddy​, you should be able to access the document now.
Installing Ubuntu Rootfs on NXP i.MX6 boards
5 回复数
4,216 次查看
卢金磊
@1990rahulreddy 你好,该问题是否解决,有没有具体的方案,我这边python一直不能支持
4,651 次查看
gusarambula
Hello Rahul Reddy ,
Yocto allows you to build a Linux root file system for your board. You may run post-scripts while building your image in Yocto as part of the image recipe, is this what you’re looking after? It would seem that you rather want to run a script on the Qt image, which would be a different procedure and you would need to make sure that you have Python installed on the Qt image.
There is not an official Ubuntu BSP for the i.MX6, however, you may follow the instructions on the following document to load an Ubuntu RootFS on the i.MX6.
4,651 次查看
1990rahulreddy
Access to this place or content is restricted. If you think this is a mistake, please contact your administrator or the person who directed you here
4,651 次查看
gusarambula
Hello Rahul Reddy,
I'm very sorry. I've escalated this so the document gets the right access settings so you may access it. It should be ready in a couple of hours.
4,652 次查看
gusarambula
