Programming nand using MFG tool
Sowmya1z
Hi everyone,
   I am trying to program nk.nb0 and eboot.nb0 to nand flash using MFG tool. While programming the eboot.nbo to the nand, i am getting "IOCTL_DISK_VENDOR_GET_IMGINFO failed error 31". So flashing is not happening. please help me to fix this.
Sowmya
daiane_angolini
Please, try to include more info like:
1- what´s the board you´re using?
2- what´s the MFGtools version?
3- what´s your software version? (what are you trying to install?
Sowmya1z
Hi Daiane,
The board i am using is imx6x board. MFG tool version is Mfgtools-Rel-12.01.01_ER_MX6Q_UPDATER. OS is WinCE 7.
Now iam able to program the image to nand using MFG tool. The error is because i didn't add the library in my eboot sources. After adding the error gone.
Thanks and Regards,
Sowmya
