Problems Setting Prescaler for PWM capture
3,367件の閲覧回数
mexp2
We are using a PWM input to capture a external frequency of a tacho.
With the standard settings everything works fine but when i apply a prescaler during initialization
pwmConfig.prescale = kPWM_Prescale_Divide_64;
or by setting it via
void PWM_SetClockMode
the values of CVAL2 and CVAL3 are always 0x00 and the counter is not counting
My signal has a frequency of 200Hz
5 返答(返信)
3,299件の閲覧回数
mexp2
We use the imxRT1062 with the SDK v 2.13.0
/* Read the PWM default configuration */
PWM_GetDefaultConfig(&pwmConfig);
pwmConfig.reloadLogic 	  = kPWM_ReloadImmediate;
pwmConfig.pairOperation   = kPWM_Independent;
pwmConfig.enableDebugMode = true;
/* Init the pwm */
if( PWM_Init(TACHOPUMP_PERIPHERAL, TACHOPUMP_CHANNEL, &pwmConfig) == kStatus_Fail)
	PRINTF("Can't initialize PWM\n");
return;
/* Configure the capture input of the PWM for one shot polling */
pwm_input_capture_param_t captureConfig;
captureConfig.captureInputSel = false;
captureConfig.edge0 = kPWM_RisingEdge;
captureConfig.edge1 = kPWM_RisingEdge;
captureConfig.enableOneShotCapture = true;
PWM_SetupInputCapture(TACHOPUMP_PERIPHERAL, TACHOPUMP_CHANNEL, TACHOPUMP_SIGNAL, &captureConfig);
PWM_SetPwmLdok(TACHOPUMP_PERIPHERAL, timerBitmask, true);
PWM_StartTimer(TACHOPUMP_PERIPHERAL, timerBitmask);
with this code everything works as expected, but if i add a prescaler in the configuration
pwmConfig.prescale = kPWM_Prescale_Divide_128;
the counter is not counting anymore
3,241件の閲覧回数
RaRo
Hello @mexp2,
First of all, we apologize for the delay to answer you.
Just for double check, could you please tell us where are you placing the kPWM_Prescale_Divide_128? It might be good if you could write the pwmConfig.prescale=kPWM_Prescale_Divide_128; after pwmConfig.pairOperation=kPWM_Independent; and before PWM_Init(). Also, which clock source are you using?
Finally, could you please try to use other values of the prescaler below 64?
Best regards, Raul.
2,049件の閲覧回数
coderick
你好,我也遇到了楼主同样的问题,将分频代码去掉或者设为1分频时,Counter可以正常运行,但是设置2分频或更高的分频时Counter就停止了,这是什么原因?
void Capture_config(void)
    pwm_input_capture_param_t pwm_input_capture;
    gpio_pin_config_t PWM_pin_config;
    //初始化输入捕获管脚
    IOMUXC_SetPinMux(PWM2_PWMA03_IOMUXC, 0U);                             //设置外部引脚的复用功能
    IOMUXC_SetPinConfig(PWM2_PWMA03_IOMUXC, PWMC_INPUT_PAD_CONFIG_DATA);     //设置引脚的 pad 属性
    PWM_pin_config.direction = kGPIO_DigitalInput;
    PWM_pin_config.interruptMode = kGPIO_NoIntmode;
    GPIO_PinInit(PWM2_PWMA03_GPIO, PWM2_PWMA03_GPIO_PIN, &PWM_pin_config);
    //初始化输入捕获配置参数
    pwm_input_capture.captureInputSel = false;
    pwm_input_capture.edge0 = kPWM_RisingEdge;
    //pwm_input_capture.edge1 = kPWM_FallingEdge;
    pwm_input_capture.enableOneShotCapture = false;
    //pwm_input_capture.edgeCompareValue = 10;  //当captureInputSel为FALSE时,此处设值无意义
    pwm_input_capture.fifoWatermark = 0;
    PWM_SetupInputCapture(PI_PWM_BASEADDR, kPWM_Module_3, kPWM_PwmA, &pwm_input_capture);
    //开启捕获中断
    //set_IRQn_Priority(PWM2_3_IRQn,Group4_PreemptPriority_0, Group4_SubPriority_0);//设置中断优先级
    //PWM_EnableInterrupts(PI_PWM_BASEADDR, kPWM_Module_3, kPWM_CaptureA0InterruptEnable| kPWM_CaptureA1InterruptEnable );
    PWM_EnableInterrupts(PI_PWM_BASEADDR, kPWM_Module_3, kPWM_CaptureA0InterruptEnable );
    EnableIRQ(PWM2_3_IRQn);
* @brief  初始化 PWM  配置参数
* @retval 无
void PWM_config(void)
    pwm_config_t pwmConfig;//定义pwm 配置结构体
    PWM_Deinit(PI_PWM_BASEADDR, kPWM_Module_3);
    /*设置AHB总线时钟和IP总线时钟*/
    CLOCK_SetDiv(kCLOCK_IpgDiv, 0x3); /* Set IPG PODF to 3, divede by 4 */
    /*设置pwm 错误输入为高电平,表示没有错误,只有当pwm 没有错误输入或者禁止错误检测才能正常输出pwm波*/
    XBARA_Init(XBARA1);
    XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1Fault0);
    XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1Fault1);
    XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1234Fault2);
    XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1234Fault3);
    pwmConfig.reloadLogic = kPWM_ReloadPwmFullCycle; //新值在上一个pwm周期输出结束之后加载到缓冲寄存器中
    pwmConfig.pairOperation = kPWM_Independent;      // 工作在独立模式
    pwmConfig.clockSource = kPWM_BusClock;
    pwmConfig.enableDebugMode = true;                // 使能DebugMode
    pwmConfig.prescale = kPWM_Prescale_Divide_128;    //1320000000/128/65535=16Hz=PWM最小频率
    //初始化 PWM 并且判断初始化是否成功
    if (PWM_Init(PI_PWM_BASEADDR, kPWM_Module_3, &pwmConfig) == kStatus_Fail)
        PRINTF("PWM initialization failed\n");
    Capture_config();
    PWM_SetPwmLdok(PI_PWM_BASEADDR,kPWM_Control_Module_3 , true);
    PWM_StartTimer(PI_PWM_BASEADDR, kPWM_Control_Module_3 );
タグ(2)
3,339件の閲覧回数
Sanket_Parekh
Hi @mexp2 ,
I hope you are doing well.
Please specify which i.MX Processor is used to debug further.
Thanks & Regards,
Sanket Parekh
1,948件の閲覧回数
isharaby
I've encountered the same issue,
when configuring the any of the four PWM peripherals clock perscaler with values other than kPWM_Prescale_Divide_1 , the counter of the selected PWM peripheral doesn't work at all.
I'm using the imxrt1062 processor and MCUXpresso IDE v11.9.1
I hope, you can support me as soon as possible.
And, here is a snippet of my code where I configure and initialize the pwm peripherals.
static void pwm_init(void)
pwm_fault_param_t faultConfig;
pwmConfig.prescale = kPWM_Prescale_Divide_2;
pwmConfig.initializationControl = kPWM_Initialize_LocalSync;
pwmConfig.reloadSelect = kPWM_LocalReload;
pwmConfig.reloadFrequency = kPWM_LoadEveryOportunity;
pwmConfig.forceTrigger = kPWM_Force_LocalSync;
PWM_Init(PWM1_BASEADDR, kPWM_Module_3, &pwmConfig);
PWM_Init(PWM2_BASEADDR, kPWM_Module_3, &pwmConfig);
PWM_Init(PWM3_BASEADDR, kPWM_Module_1, &pwmConfig);
PWM_Init(PWM4_BASEADDR, kPWM_Module_1, &pwmConfig);
// fault configuration
PWM_FaultDefaultConfig(&faultConfig);
/* Sets up the PWM fault protection */
PWM_SetupFaults(PWM1_BASEADDR, kPWM_Fault_0, &faultConfig);
PWM_SetupFaults(PWM1_BASEADDR, kPWM_Fault_1, &faultConfig);
PWM_SetupFaults(PWM1_BASEADDR, kPWM_Fault_2, &faultConfig);
PWM_SetupFaults(PWM1_BASEADDR, kPWM_Fault_3, &faultConfig);
/* Set PWM fault disable mapping for submodule 0/1/2 */
PWM_SetupFaultDisableMap(PWM1_BASEADDR, kPWM_Module_0, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaultDisableMap(PWM1_BASEADDR, kPWM_Module_1, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaultDisableMap(PWM1_BASEADDR, kPWM_Module_2, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaultDisableMap(PWM1_BASEADDR, kPWM_Module_3, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaults(PWM2_BASEADDR, kPWM_Fault_0, &faultConfig);
PWM_SetupFaults(PWM2_BASEADDR, kPWM_Fault_1, &faultConfig);
PWM_SetupFaults(PWM2_BASEADDR, kPWM_Fault_2, &faultConfig);
PWM_SetupFaults(PWM2_BASEADDR, kPWM_Fault_3, &faultConfig);
PWM_SetupFaultDisableMap(PWM2_BASEADDR, kPWM_Module_0, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaultDisableMap(PWM2_BASEADDR, kPWM_Module_1, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaultDisableMap(PWM2_BASEADDR, kPWM_Module_2, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaultDisableMap(PWM2_BASEADDR, kPWM_Module_3, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaults(PWM3_BASEADDR, kPWM_Fault_0, &faultConfig);
PWM_SetupFaults(PWM3_BASEADDR, kPWM_Fault_1, &faultConfig);
PWM_SetupFaults(PWM3_BASEADDR, kPWM_Fault_2, &faultConfig);
PWM_SetupFaults(PWM3_BASEADDR, kPWM_Fault_3, &faultConfig);
PWM_SetupFaultDisableMap(PWM3_BASEADDR, kPWM_Module_0, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaultDisableMap(PWM3_BASEADDR, kPWM_Module_1, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaultDisableMap(PWM3_BASEADDR, kPWM_Module_2, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaultDisableMap(PWM3_BASEADDR, kPWM_Module_3, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaults(PWM4_BASEADDR, kPWM_Fault_0, &faultConfig);
PWM_SetupFaults(PWM4_BASEADDR, kPWM_Fault_1, &faultConfig);
PWM_SetupFaults(PWM4_BASEADDR, kPWM_Fault_2, &faultConfig);
PWM_SetupFaults(PWM4_BASEADDR, kPWM_Fault_3, &faultConfig);
PWM_SetupFaultDisableMap(PWM4_BASEADDR, kPWM_Module_0, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaultDisableMap(PWM4_BASEADDR, kPWM_Module_1, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaultDisableMap(PWM4_BASEADDR, kPWM_Module_2, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaultDisableMap(PWM4_BASEADDR, kPWM_Module_3, kPWM_PwmA, kPWM_faultchannel_0, kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
captureConfig.captureInputSel = true;
captureConfig.edge0 = kPWM_RiseAndFallEdge;
captureConfig.edge1 = kPWM_Disable;
captureConfig.enableOneShotCapture = false;
captureConfig.edgeCompareValue = 1;
PWM_SetupInputCapture(PWM1_BASEADDR, kPWM_Module_3, kPWM_PwmA, &captureConfig);
PWM_SetupInputCapture(PWM2_BASEADDR, kPWM_Module_3, kPWM_PwmA, &captureConfig);
PWM_SetupInputCapture(PWM3_BASEADDR, kPWM_Module_1, kPWM_PwmA, &captureConfig);
PWM_SetupInputCapture(PWM4_BASEADDR, kPWM_Module_1, kPWM_PwmA, &captureConfig);
PWM_SetPwmLdok(PWM1_BASEADDR, kPWM_Control_Module_3, true);
PWM_SetPwmLdok(PWM2_BASEADDR, kPWM_Control_Module_3, true);
PWM_SetPwmLdok(PWM3_BASEADDR, kPWM_Control_Module_1, true);
PWM_SetPwmLdok(PWM4_BASEADDR, kPWM_Control_Module_1, true);
PWM_StartTimer(PWM1_BASEADDR, kPWM_Control_Module_3);
PWM_StartTimer(PWM2_BASEADDR, kPWM_Control_Module_3);
PWM_StartTimer(PWM3_BASEADDR, kPWM_Control_Module_1);
PWM_StartTimer(PWM4_BASEADDR, kPWM_Control_Module_1);
%3CLINGO-SUB%20id%3D%22lingo-sub-1684880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPWM%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%AE%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E8%A8%AD%E5%AE%9A%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1684880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%BF%E3%82%B3%E3%81%AE%E5%A4%96%E9%83%A8%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20PWM%20%E5%85%A5%E5%8A%9B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%A8%99%E6%BA%96%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%88%9D%E6%9C%9F%E5%8C%96%E4%B8%AD%E3%81%AB%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%3C%2FP%3E%3CP%3E%3CSPAN%3EpwmConfig.%3C%2FSPAN%3E%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CI%3EkPWM_Prescale_Divide_64%3C%2FI%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSTRONG%3EPWM_SetClockMode%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3ECVAL2%E3%81%A8CVAL3%E3%81%AE%E5%80%A4%E3%81%AF%E5%B8%B8%E3%81%AB0x00%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%81%AF%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AF200Hz%E3%81%A7%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problems%20Setting%20Prescaler%20for%20PWM%20capture%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CDIV%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%204%20%E3%81%A4%E3%81%AE%20PWM%20%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%91%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E3%82%92%20kPWM_Prescale_Divide_1%20%E4%BB%A5%E5%A4%96%E3%81%AE%E5%80%A4%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%3CSPAN%3E%E3%80%81%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%20PWM%20%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AFimxrt1062%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%A8MCUXpresso%20IDE%20v11.9.1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E6%97%A9%E3%81%8F%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81PWM%20%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%8A%E3%82%88%E3%81%B3%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%E9%9D%99%E7%9A%84%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Epwm_init%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Epwm_config_t%3C%2FSPAN%3E%20%3CSPAN%3EpwmConfig%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Epwm_input_capture_param_t%3C%2FSPAN%3E%3CSPAN%3E%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E8%A8%AD%E5%AE%9A%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Epwm_fault_param_t%3C%2FSPAN%3E%3CSPAN%3E%E9%9A%9C%E5%AE%B3%E6%A7%8B%E6%88%90%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F*%20PWM%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E8%A8%AD%E5%AE%9A%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_GetDefaultConfig(%26amp%3BpwmConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EpwmConfig.clockSource%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_BusClock%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EpwmConfig.prescale%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Prescale_Divide_2%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EpwmConfig.pairOperation%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Independent%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EpwmConfig.initializationControl%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Initialize_LocalSync%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EpwmConfig.%3C%2FSPAN%3E%20%3CSPAN%3EreloadLogic%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_ReloadImmediate%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EpwmConfig.%3C%2FSPAN%3E%20%3CSPAN%3EreloadSelect%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_LocalReload%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EpwmConfig.%3C%2FSPAN%3E%20%3CSPAN%3EreloadFrequency%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_LoadEveryOportunity%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EpwmConfig.forceTrigger%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Force_LocalSync%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EpwmConfig.enableDebugMode%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Etrue%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EPWM_Init(PWM1_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BpwmConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_Init(PWM2_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BpwmConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_Init(PWM3_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BpwmConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_Init(PWM4_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BpwmConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F%2F%20%E9%9A%9C%E5%AE%B3%E6%A7%8B%E6%88%90%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_FaultDefaultConfig(%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20PWM%E9%9A%9C%E5%AE%B3%E4%BF%9D%E8%AD%B7%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM1_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM1_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM1_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_2%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM1_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F*%20%E3%82%B5%E3%83%96%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB0%2F1%2F2%E3%81%AEPWM%E9%9A%9C%E5%AE%B3%E7%84%A1%E5%8A%B9%E5%8C%96%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM1_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM1_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM1_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_2%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM1_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F*%20PWM%E9%9A%9C%E5%AE%B3%E4%BF%9D%E8%AD%B7%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM2_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM2_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM2_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_2%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM2_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F*%20%E3%82%B5%E3%83%96%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB0%2F1%2F2%E3%81%AEPWM%E9%9A%9C%E5%AE%B3%E7%84%A1%E5%8A%B9%E5%8C%96%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM2_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM2_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM2_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_2%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM2_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F*%20PWM%E9%9A%9C%E5%AE%B3%E4%BF%9D%E8%AD%B7%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM3_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM3_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM3_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_2%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM3_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F*%20%E3%82%B5%E3%83%96%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB0%2F1%2F2%E3%81%AEPWM%E9%9A%9C%E5%AE%B3%E7%84%A1%E5%8A%B9%E5%8C%96%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM3_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM3_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM3_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_2%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM3_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F*%20PWM%E9%9A%9C%E5%AE%B3%E4%BF%9D%E8%AD%B7%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM4_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM4_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM4_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_2%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaults(PWM4_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Fault_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BfaultConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F*%20%E3%82%B5%E3%83%96%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB0%2F1%2F2%E3%81%AEPWM%E9%9A%9C%E5%AE%B3%E7%84%A1%E5%8A%B9%E5%8C%96%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM4_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM4_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM4_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_2%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupFaultDisableMap(PWM4_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_faultchannel_0%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_2%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_FaultDisable_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F*%20%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E7%94%A8%E3%81%AEPWM%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E5%85%A5%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3Config.captureInputSel%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Etrue%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E6%A7%8B%E6%88%90%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%83%E3%82%B80%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_RiseAndFallEdge%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3EConfig.edge1%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Disable%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E%E3%80%82enableOneShotCapture%3C%2FSPAN%3E%20%3CSPAN%3E%3D%20false%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3CSPAN%3E%E6%A7%8B%E6%88%90%3C%2FSPAN%3E%3CSPAN%3E%E3%80%82edgeCompareValue%3C%2FSPAN%3E%20%3CSPAN%3E%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EPWM_SetupInputCapture(PWM1_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BcaptureConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupInputCapture(PWM2_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BcaptureConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupInputCapture(PWM3_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BcaptureConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetupInputCapture(PWM4_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Module_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_PwmA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%26amp%3BcaptureConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EPWM_SetPwmLdok(PWM1_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Control_Module_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81true)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetPwmLdok(PWM2_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Control_Module_3%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81true)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetPwmLdok(PWM3_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Control_Module_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81true)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_SetPwmLdok(PWM4_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Control_Module_1%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81true)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EPWM_StartTimer(PWM1_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Control_Module_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_StartTimer(PWM2_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Control_Module_3%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_StartTimer(PWM3_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Control_Module_1%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPWM_StartTimer(PWM4_BASEADDR%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EkPWM_Control_Module_1%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195377%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3EProblems%20Setting%20the%20Prescaler%20for%20PWM%20capture%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195377%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E5%85%83%E3%81%AE%E6%8A%95%E7%A8%BF%E8%80%85%E3%81%A8%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%95%E5%88%87%E3%82%8A%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81%E4%BB%95%E5%88%87%E3%82%8A1%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E3%81%A8%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BB%95%E5%88%87%E3%82%8A2%E4%BB%A5%E4%B8%8A%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Evoid%20Capture_config(void)%0A%7B%0A%20%20%20%20pwm_input_capture_param_t%20pwm_input_capture%3B%0A%20%20%20%20gpio_pin_config_t%20PWM_pin_config%3B%0A%20%20%0A%20%20%20%20%2F%2F%E5%88%9D%E5%A7%8B%E5%8C%96%E8%BE%93%E5%85%A5%E6%8D%95%E8%8E%B7%E7%AE%A1%E8%84%9A%0A%20%20%20%20IOMUXC_SetPinMux(PWM2_PWMA03_IOMUXC%2C%200U)%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%E8%AE%BE%E7%BD%AE%E5%A4%96%E9%83%A8%E5%BC%95%E8%84%9A%E7%9A%84%E5%A4%8D%E7%94%A8%E5%8A%9F%E8%83%BD%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20IOMUXC_SetPinConfig(PWM2_PWMA03_IOMUXC%2C%20PWMC_INPUT_PAD_CONFIG_DATA)%3B%20%20%20%20%20%2F%2F%E8%AE%BE%E7%BD%AE%E5%BC%95%E8%84%9A%E7%9A%84%20pad%20%E5%B1%9E%E6%80%A7%20%0A%0A%20%20%20%20PWM_pin_config.direction%20%3D%20kGPIO_DigitalInput%3B%0A%20%20%20%20PWM_pin_config.interruptMode%20%3D%20kGPIO_NoIntmode%3B%0A%0A%20%20%20%20GPIO_PinInit(PWM2_PWMA03_GPIO%2C%20PWM2_PWMA03_GPIO_PIN%2C%20%26amp%3BPWM_pin_config)%3B%0A%0A%20%20%20%20%2F%2F%E5%88%9D%E5%A7%8B%E5%8C%96%E8%BE%93%E5%85%A5%E6%8D%95%E8%8E%B7%E9%85%8D%E7%BD%AE%E5%8F%82%E6%95%B0%0A%20%20%20%20pwm_input_capture.captureInputSel%20%3D%20false%3B%0A%20%20%20%20pwm_input_capture.edge0%20%3D%20kPWM_RisingEdge%3B%0A%20%20%20%20%2F%2Fpwm_input_capture.edge1%20%3D%20kPWM_FallingEdge%3B%0A%20%20%20%20pwm_input_capture.enableOneShotCapture%20%3D%20false%3B%0A%20%20%20%20%2F%2Fpwm_input_capture.edgeCompareValue%20%3D%2010%3B%20%20%2F%2F%E5%BD%93captureInputSel%E4%B8%BAFALSE%E6%97%B6%EF%BC%8C%E6%AD%A4%E5%A4%84%E8%AE%BE%E5%80%BC%E6%97%A0%E6%84%8F%E4%B9%89%0A%20%20%20%20pwm_input_capture.fifoWatermark%20%3D%200%3B%0A%20%20%20%20PWM_SetupInputCapture(PI_PWM_BASEADDR%2C%20kPWM_Module_3%2C%20kPWM_PwmA%2C%20%26amp%3Bpwm_input_capture)%3B%0A%0A%20%20%20%20%2F%2F%E5%BC%80%E5%90%AF%E6%8D%95%E8%8E%B7%E4%B8%AD%E6%96%AD%0A%20%20%20%20%2F%2Fset_IRQn_Priority(PWM2_3_IRQn%2CGroup4_PreemptPriority_0%2C%20Group4_SubPriority_0)%3B%2F%2F%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%96%AD%E4%BC%98%E5%85%88%E7%BA%A7%0A%20%20%20%20%2F%2FPWM_EnableInterrupts(PI_PWM_BASEADDR%2C%20kPWM_Module_3%2C%20kPWM_CaptureA0InterruptEnable%7C%20kPWM_CaptureA1InterruptEnable%20)%3B%0A%20%20%20%20PWM_EnableInterrupts(PI_PWM_BASEADDR%2C%20kPWM_Module_3%2C%20kPWM_CaptureA0InterruptEnable%20)%3B%0A%20%20%20%20EnableIRQ(PWM2_3_IRQn)%3B%20%20%0A%7D%0A%0A%20%2F**%0A*%20%40brief%20%20%E5%88%9D%E5%A7%8B%E5%8C%96%20PWM%20%20%E9%85%8D%E7%BD%AE%E5%8F%82%E6%95%B0%20%0A*%20%40retval%20%E6%97%A0%0A*%2F%0Avoid%20PWM_config(void)%0A%7B%0A%20%20%20%20pwm_config_t%20pwmConfig%3B%2F%2F%E5%AE%9A%E4%B9%89pwm%20%E9%85%8D%E7%BD%AE%E7%BB%93%E6%9E%84%E4%BD%93%0A%0A%20%20%20%20PWM_Deinit(PI_PWM_BASEADDR%2C%20kPWM_Module_3)%3B%0A%20%20%20%20%2F*%E8%AE%BE%E7%BD%AEAHB%E6%80%BB%E7%BA%BF%E6%97%B6%E9%92%9F%E5%92%8CIP%E6%80%BB%E7%BA%BF%E6%97%B6%E9%92%9F*%2F%0A%20%20%20%20CLOCK_SetDiv(kCLOCK_IpgDiv%2C%200x3)%3B%20%2F*%20Set%20IPG%20PODF%20to%203%2C%20divede%20by%204%20*%2F%0A%0A%20%20%20%20%2F*%E8%AE%BE%E7%BD%AEpwm%20%E9%94%99%E8%AF%AF%E8%BE%93%E5%85%A5%E4%B8%BA%E9%AB%98%E7%94%B5%E5%B9%B3%EF%BC%8C%E8%A1%A8%E7%A4%BA%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%BD%93pwm%20%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%E8%BE%93%E5%85%A5%E6%88%96%E8%80%85%E7%A6%81%E6%AD%A2%E9%94%99%E8%AF%AF%E6%A3%80%E6%B5%8B%E6%89%8D%E8%83%BD%E6%AD%A3%E5%B8%B8%E8%BE%93%E5%87%BApwm%E6%B3%A2*%2F%0A%20%20%20%20XBARA_Init(XBARA1)%3B%0A%20%20%20%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1Fault0)%3B%0A%20%20%20%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1Fault1)%3B%0A%20%20%20%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1234Fault2)%3B%0A%20%20%20%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1234Fault3)%3B%20%0A%20%20%20%20%0A%20%20%20%20PWM_GetDefaultConfig(%26amp%3BpwmConfig)%3B%0A%20%20%20%20pwmConfig.reloadLogic%20%3D%20kPWM_ReloadPwmFullCycle%3B%20%2F%2F%E6%96%B0%E5%80%BC%E5%9C%A8%E4%B8%8A%E4%B8%80%E4%B8%AApwm%E5%91%A8%E6%9C%9F%E8%BE%93%E5%87%BA%E7%BB%93%E6%9D%9F%E4%B9%8B%E5%90%8E%E5%8A%A0%E8%BD%BD%E5%88%B0%E7%BC%93%E5%86%B2%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%0A%20%20%20%20pwmConfig.pairOperation%20%3D%20kPWM_Independent%3B%20%20%20%20%20%20%2F%2F%20%E5%B7%A5%E4%BD%9C%E5%9C%A8%E7%8B%AC%E7%AB%8B%E6%A8%A1%E5%BC%8F%0A%20%20%20%20pwmConfig.clockSource%20%3D%20kPWM_BusClock%3B%0A%20%20%20%20pwmConfig.enableDebugMode%20%3D%20true%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20%E4%BD%BF%E8%83%BDDebugMode%20%0A%20%20%20%20pwmConfig.prescale%20%3D%20kPWM_Prescale_Divide_128%3B%20%20%20%20%2F%2F1320000000%2F128%2F65535%3D16Hz%3DPWM%E6%9C%80%E5%B0%8F%E9%A2%91%E7%8E%87%0A%0A%20%20%20%20%2F%2F%E5%88%9D%E5%A7%8B%E5%8C%96%20PWM%20%E5%B9%B6%E4%B8%94%E5%88%A4%E6%96%AD%E5%88%9D%E5%A7%8B%E5%8C%96%E6%98%AF%E5%90%A6%E6%88%90%E5%8A%9F%0A%20%20%20%20if%20(PWM_Init(PI_PWM_BASEADDR%2C%20kPWM_Module_3%2C%20%26amp%3BpwmConfig)%20%3D%3D%20kStatus_Fail)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20PRINTF(%22PWM%20initialization%20failed%5Cn%22)%3B%0A%20%20%20%20%7D%0A%20%20%20%20Capture_config()%3B%0A%20%20%20%20PWM_SetPwmLdok(PI_PWM_BASEADDR%2CkPWM_Control_Module_3%20%2C%20true)%3B%20%20%20%0A%20%20%20%20PWM_StartTimer(PI_PWM_BASEADDR%2C%20kPWM_Control_Module_3%20)%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1691605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problems%20Setting%20Prescaler%20for%20PWM%20capture%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1691605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F220142%22%20target%3D%22_blank%22%3E%40mexp2%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3E%E3%81%BE%E3%81%9A%E5%88%9D%E3%82%81%E3%81%AB%E3%80%81%E3%81%94%E8%BF%94%E7%AD%94%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E8%A9%AB%E3%81%B3%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3E%E5%BF%B5%E3%81%AE%E3%81%9F%E3%82%81%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%20%3CEM%3EkPWM_Prescale_Divide_128%3C%2FEM%3E%E3%82%92%E3%81%A9%E3%81%93%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CEM%3EpwmConfig.prescale%3DkPWM_Prescale_Divide_128%3B%3C%2FEM%3E%E3%81%A8%E8%A8%98%E8%BF%B0%E3%81%99%E3%82%8B%E3%81%A8%E8%89%AF%E3%81%84%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CEM%3EpwmConfig.pairOperation%3DkPWM_Independent%20%E3%81%AE%E5%BE%8C%3B%3C%2FEM%3E%3CEM%3EPWM_Init()%3C%2FEM%3E%E3%81%AE%E5%89%8D%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%81%A9%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3E%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E3%81%AE%E5%80%A4%E3%82%92%2064%20%E6%9C%AA%E6%BA%80%E3%81%AB%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E3%83%A9%E3%82%A6%E3%83%AB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1688240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problems%20Setting%20Prescaler%20for%20PWM%20capture%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1688240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EimxRT1062%E3%82%92SDK%20v2.13.0%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F*%20Read%20the%20PWM%20default%20configuration%20*%2F%0APWM_GetDefaultConfig(%26amp%3BpwmConfig)%3B%0A%0ApwmConfig.reloadLogic%20%09%20%20%3D%20kPWM_ReloadImmediate%3B%0ApwmConfig.pairOperation%20%20%20%3D%20kPWM_Independent%3B%0ApwmConfig.enableDebugMode%20%3D%20true%3B%0A%0A%2F*%20Init%20the%20pwm%20*%2F%0Aif(%20PWM_Init(TACHOPUMP_PERIPHERAL%2C%20TACHOPUMP_CHANNEL%2C%20%26amp%3BpwmConfig)%20%3D%3D%20kStatus_Fail)%0A%7B%0A%09PRINTF(%22Can't%20initialize%20PWM%5Cn%22)%3B%0Areturn%3B%0A%7D%0A%0A%2F*%20Configure%20the%20capture%20input%20of%20the%20PWM%20for%20one%20shot%20polling%20*%2F%0Apwm_input_capture_param_t%20captureConfig%3B%0A%0AcaptureConfig.captureInputSel%20%3D%20false%3B%0AcaptureConfig.edge0%20%3D%20kPWM_RisingEdge%3B%0AcaptureConfig.edge1%20%3D%20kPWM_RisingEdge%3B%0AcaptureConfig.enableOneShotCapture%20%3D%20true%3B%0A%0APWM_SetupInputCapture(TACHOPUMP_PERIPHERAL%2C%20TACHOPUMP_CHANNEL%2C%20TACHOPUMP_SIGNAL%2C%20%26amp%3BcaptureConfig)%3B%0A%0APWM_SetPwmLdok(TACHOPUMP_PERIPHERAL%2C%20timerBitmask%2C%20true)%3B%0A%0APWM_StartTimer(TACHOPUMP_PERIPHERAL%2C%20timerBitmask)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E6%9C%9F%E5%BE%85%E9%80%9A%E3%82%8A%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3EpwmConfig.prescale%20%3D%20kPWM_Prescale_Divide_128%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AF%E3%82%82%E3%81%86%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1685604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problems%20Setting%20Prescaler%20for%20PWM%20capture%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1685604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F220142%22%20target%3D%22_blank%22%3E%40mexp2%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%85%83%E6%B0%97%E3%81%A7%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20i.MX%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%82%3CBR%20%2F%3E%E3%82%B5%E3%83%B3%E3%82%B1%E3%83%88%E3%83%BB%E3%83%91%E3%83%AC%E3%83%83%E3%82%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
