Hello, I am using IMX6 board for porting of GPU applications for which i require this toolchain : gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12. As per my search, it should be found in Latest linux BSPs provided by freescale but i do not know which release of linux contains this and if it is present, i want to know the path in that BSP. could anyone please help me with it? Thanks in advancePr
解決済! 解決策の投稿を見る。
Please use "gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1.i386.rpm",
that may be found in pkgs directory of "L3.0.35_4.1.0_130816_source.tar.gz"
Summary Page :
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=i.MX6Q&fpsp=1&tab=Design_Tools_Tab
Yuri
Summary Page :
Yuri
Do you know where I can find the glibc-2.13 source used to build the libraries that are part of that RPM? I need to patch the libresolv code to fix the recently discovered getaddrinfo() problem (https://sourceware.org/ml/libc-alpha/2016-02/msg00416.html ).
The glibc source is not included in that RPM, nor AFAIK in the L3.0.35_4.1.0_130816_source.tar.gz tarball.
Thanks.
-David
Thank you Yuri
