Problem in Playing ogg video files with aiurdemux on imx6q sabrelite
bhuvaneshsurach
   I am trying to play ogg files using gst-launch with the pipeline below:
gst-launch-0.10 filesrc location= <ogg video file path> typefind=true ! aiurdemux ! queue ! vpudec ! ffmpegcolorspace ! mfw_v4lsink
Getting the following error:
[CreateParser} failed ret=-21 from the aiurdemuxer.
I am using gst-fsl-plugins version 3.0.5.
Could you please help in getting this issue resolved?
Labels (3)
LeonardoSandova
Specialist I
Have you tried other ogg files? also, I think you can avoid the color space element, unless you want to do some color conversion or rescaling stuff. If this the case, you can use the HW-accelerated element called mfw_ipucsc.
Leo
