Power supply for eMMC
3,131 次查看
huydt1
I'm design new device with imx7D saber as reference.
For reducing the extra LDO for suppling power to eMMC, I supply power eMMC by the LDO4 of PC32PF3000A1EP (LDO4: 3.3V, 350mA max, supply power to eMMC only)
Please help me check whether this modify is ok or not!
Thanks and best regards,
Dinh Huy
标签 (2)
2,873 次查看
igorpadykov
Hi DINH
seems this will be fine, provided that processor power up sequence is
followed, 350mA should be sufficient for normal emmc operation.
2,874 次查看
igorpadykov
Hi DINH
2,873 次查看
huydt1
Thanks for your support
Dinh Huy
