Porting legacy linux application to freertos (i.MX)
ranjay_shandilya
I am trying to port an existing C++ application running on linux currently to freertos.
My application has various custom libraries ( prj_lib1, prj_lib2, ...... prj_lib9) which I wanna link to one .exe(Project_main.exe)
I just need a bit of clarification on how to proceed in this scenario.
Do I need to create freertos static library for each library to link in the Project_main.exe or normal c++ static library should be good enough?
Currently what I am doing is, I have generated Project_main.exe by modifying an existing demo application. And then created normal C++ static library for different libraries which I link in the Project_main.exe.
Is this the correct way to go ahead? Or should I modify existing demo application to generate libraries too?
If there's some other way please do let me know.
