Porting Hypervisor on IMX6
3,870 次查看
deepika_t
Hi, I am working on imx6 sabre auto. I need to port Xen hypervisor on it with Linux OS. Is it possible?
Do you have any document for how to make it working.
Thanks in advance
Deepika
标记 (1)
2,864 次查看
gary_bisson
Senior Contributor III
Hi Deepika,
No you can't port the Xen hypervisor since it requires an ARM processor with Virtualization instructions like the Cortex-A15 or Cortex-A7. The Cortex-A9 of the i.MX6Q doesn't have those instructions.
https://wiki.xenproject.org/wiki/Xen_ARM_with_Virtualization_Extensions
Gary
2,864 次查看
deepika_t
Thanks Bisson,
Can you give me suggestions on what board should I start with?
Deepika
2,865 次查看
gary_bisson
Hi Deepika,
Gary
