Plug and play camera modules on IMX8MM android
1,140件の閲覧回数
ganesh_k
Hi Team,
OS info:
Kernel : 5.4.7
Android version: 11.0.0
Requirement:
    We want to use the plug and play camera sensor modules which are 8MP or more with the above mentioned kernel source. Please provide the list of camera sensor modules that are compatible with IMX8MM(android).
Thanks & Regards
Ganesh.K
1,124件の閲覧回数
Chavira
Hi@ganesh_k!
Thank you for contacting NXP Support!
The supported camera modules supported for that version are "i.MX CSI MIPI camera" and "Basler CSI MIPI camera".
In the document called "ANDROID_QUICK_START_GUIDE.pdf," you can see all the modules available for our pre-compiled images.
You can see all the documentation following the link:
https://www.nxp.com/design/software/embedded-software/i-mx-software/android-os-for-i-mx-applications...
