Missing sd8997.ko driver
1,636 次查看
GuyB123
Hey,
Currently trying to run the AzuraWave AW-CM276NF-EVB on my linux (Linux corecard 4.14.98-imx8-r90), following the instructions from AzuraWave, but i seem to be missing the sd8997.ko / sd8xxx.ko driver and the sdio8997_uart_combo.bin.
Is this something you can share for my linux build?
(having a hard time getting it from AzuraWave)
Guy.
1 回复
1,621 次查看
Chavira
Hi @GuyB123
Thank you for contacting NXP Support!
You can download the drivers by following the link:
SD-WLAN-UART-BT-8997-U16-X86-16.92.21.p41-16.92.21.p41-MM5X16322.P3-GPL (nxp.com)
Also, you can see the User guide following the link:
https://www.azurewave.com/img/nxp/AW-CM276NF-EVB_v02_User%20Guide_20210611.pdf
