Phone Call use case im8qxp
2,307 次查看
Ashil
I was looking for use case where I want to connect a mobile phone with imx8qxp and bluetooth headset to imx8qxp. I had a GUI for the use case. But I wanted to know how I can get to know how the phone call can be detected in NXP imx8qxp
5 回复数
2,291 次查看
Rita_Wang
I have create one case for it and will update to you there.
2,289 次查看
Ashil
Thanks for cloning the case. A2DP use case is what I needed.
But also need to direct call from phone to a headset . where both headset and phone will be connected to the imx8mplus or imx8qxp. Is there any examples for this scenario. If shard that will be really helpful
2,281 次查看
Ashil
The EVK I am using was imx8qxp and imx8mplus. Can I follow the HFP case you mentioned in those boards
标记 (1)
2,262 次查看
Rita_Wang
The document is based on the i.MX8QM, you can refer to it on the i.MX8QXP. For the i.MX8MP the method is the same.
2,275 次查看
Ashil
But also need to direct call from phone to a BT headset . where both BT headset and phone will be connected to the imx8mplus or imx8qxp. Is there any examples for this scenario. If shard that will be really helpful.
Is this use case tried and verified
Where Mobile phone is HFP AG to imx8qxp and from imx8qxp to BT headset HFP client I need this bluetooth path to be working
