Performance Ethernet AVB on i.MXRT1170
669 次查看
swendt38
Are there more performance measurements available for Ethernet AVB on i.MXRT ?
In NXP GenAVB/TSN Stack FreeRTOSRelease Notes (GAVBFRRN) there is only one use case (1 stereo stream) mentioned ? How does CPU load scale when raising the channel count per stream from e.g. 2 to 8 channels and how does it scale on having multiple streams ?
Is main CPU load caused by interrupt handling or by copying data or ... ?
645 次查看
Hui_Ma
We have some NXP GenAVB/TSN stack performance data, while those data was confidential.
Please use our online support channel to submit a service ticket.
Thank you for the understanding.
best regards,
Mike
