Parallel Programming System for i.MX93 Processors
Aslam_CS
I am using a imx93 processor i need to program two boards at a time. But whenever i try that on of the boards get an HID(W) error and others flashing gets completed successfully.
uu.exe -m 1:10 -b uuu-xxxxxx.flash
uu.exe -m 1:7 -b uuu-xxxxxx.flash
Even when i specify the path(1:10,1:7) i get the same error.
Please guide.
JorgeCas
Please try to run the next command:
uuu -d -m 1:7 -m 1:10 uuu-xxxxxx.flash
What do yo get with:
uuu -lsusb
Please make sure that you are using the correct port according to the enumeration.
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2398387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EParallel%20Programming%20System%20for%20i.MX93%20Processors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20using%20a%20imx93%20processor%20i%20need%20to%20program%20two%20boards%20at%20a%20time.%20But%20whenever%20i%20try%20that%20on%20of%20the%20boards%20get%20an%3CSTRONG%3E%20HID(W)%3C%2FSTRONG%3E%20error%20and%20others%20flashing%20gets%20completed%20successfully.%3C%2FP%3E%3CP%3E%3CSTRONG%3Euu.exe%20-m%201%3A10%20-b%20uuu-xxxxxx.flash%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Euu.exe%20-m%201%3A7%20-b%20uuu-xxxxxx.flash%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EEven%20when%20i%20specify%20the%20path(1%3A10%2C1%3A7)%20i%20get%20the%20same%20error.%3CBR%20%2F%3EPlease%20guide.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2398425%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Parallel%20Programming%20System%20for%20i.MX93%20Processors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398425%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EPlease%20try%20to%20run%20the%20next%20command%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3Euuu%20-d%20-m%201%3A7%20-m%201%3A10%20uuu-xxxxxx.flash%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EWhat%20do%20yo%20get%20with%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3Euuu%20-lsusb%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EPlease%20make%20sure%20that%20you%20are%20using%20the%20correct%20port%20according%20to%20the%20enumeration.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
