PXP in Windows Graphics Architecture
1,456 次查看
krestic
does the WDDM get in the way of using NXPs PXP? Seemingly Windows Desktop Window Manager is tightly coupled with DirectX which as of my understanding requires a WDDM compliant driver or it goes back to using WARP. Is it possible to make use of the PXP in Windows architecture?
标签 (2)
1,414 次查看
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
Windows support has been moved to pro-services, I would recommend to explore the demo image provided and the graphic driver used could be determined, though.
