PRELU compilation error on iMX8MP
ソリューションへジャンプ
5,011件の閲覧回数
jetxeberria
I'm having issues compiling my model with PReLU activation for iMX8MP. This operation is supposed to be supported.
I'm converting and quantizing (to int8) the model from keras to tflite using quantization aware training with native tflite methods
k_model = keras.models.load_model(path_keras)
print("Converting Keras model to int8 tflite format")
converter = tf.lite.TFLiteConverter.from_keras_model(k_model)
converter.target_spec.supported_ops = [
tf.lite.OpsSet.TFLITE_BUILTINS,
tf.lite.OpsSet.TFLITE_BUILTINS_INT8,
converter.optimizations = [tf.lite.Optimize.DEFAULT]
converter.representative_dataset = tf.lite.RepresentativeDataset(
ImageDataset(shuffle=True, limit=200, channel_first=False, input_name="input_1").generator
converter.target_spec.supported_ops = [tf.lite.OpsSet.TFLITE_BUILTINS_INT8]
converter.inference_input_type = tf.int8
converter.inference_output_type = tf.int8
tflite_model = converter.convert()
with open(path_tflite, "wb") as f:
f.write(tflite_model)
This is the error:
Vx delegate: allowed_cache_mode set to 0.
Vx delegate: device num set to 0.
Vx delegate: allowed_builtin_code set to 0.
Vx delegate: error_during_init set to 0.
Vx delegate: error_during_prepare set to 0.
Vx delegate: error_during_invoke set to 0.
input: serving_default_input_1:0shape: [ 1 112 112 3] dtype: <class 'numpy.int8'>
W [HandleLayoutInfer:274]Op 162: default layout inference pass.
(267:0) : error : Error(0,267) : Cannot find the header file cl_viv_vx_ext.h.
(25:0) : error : undefined identifier: 'COPY'
(59:0) : error : undefined identifier: 'COPY'
(270:0) : error : syntax error at 'VXC_512Bits'
ERROR: Failed to compile vx shader. (error: FFFFFFFF)
E [kernel/vsi_nn_kernel.c:_gpu_register:600]Build program fail.
E [kernel/vsi_nn_kernel.c:vsi_nn_kernel_create_node:874]Register client kernel com.vivantecorp.extension.evis.prelu_U8U8toU8_2D fail with -1.
This is repeated for 49 times and then this last error is shown:
Do you identify this error? PReLU is supposed to work, why am I seeing this error?
Thanks in advance
4,879件の閲覧回数
JeFi
I had an similar error this week. For me it was the missing header file cl_viv_vx_ext.h that is also missing in the error message. I think it was in the opencl recipe and the header file is only copied on the yocto image if something happens (its been too long), but what you can try: just create the header file with
https://github.com/larrylart/codrive/blob/master/hw_sampling/vim3_npu/include/aml_sdk/CL/cl_viv_vx_e...
and place it in the folder of youre executable.
Best wishes
5 返答(返信)
4,880件の閲覧回数
JeFi
Best wishes
4,858件の閲覧回数
jorgemf
This worked. Thanks!
タグ(1)
4,888件の閲覧回数
Bio_TICFSL
Hello.
Does this happens on 6.6.3v BSP? since is the first one that support PRELU.
4,881件の閲覧回数
jetxeberria
Hello Bio_TICFSL,
Thanks for your response.
We're using Kirkstone 5.15.71_2.2.0. Docs say it's supported: https://github.com/nxp-imx/tflite-vx-delegate-imx/blob/lf-5.15.71_2.2.0/op_status.md
4,885件の閲覧回数
jorgemf
it should be supported, at least it is state int he docs: https://github.com/nxp-imx/tflite-vx-delegate-imx/blob/lf-5.15.5_1.0.0/op_status.md
%3CLINGO-SUB%20id%3D%22lingo-sub-1847024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX8MP%E3%81%A7%E3%81%AEPRELU%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1847024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EiMX8MP%20%E3%81%AE%20PReLU%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%99%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%93%8D%E4%BD%9C%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96tflite%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E9%87%8F%E5%AD%90%E5%8C%96%E8%AA%8D%E8%AD%98%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92keras%E3%81%8B%E3%82%89tflite%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%8A%E3%82%88%E3%81%B3%E9%87%8F%E5%AD%90%E5%8C%96(int8%E3%81%AB)%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%3Ek_model%20%3D%20keras.models.load_model(path_keras)%3CBR%20%2F%3Eprint(%22Keras%20%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%20int8%20tflite%20%E5%BD%A2%E5%BC%8F%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%22)%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%20%3D%20tf.lite.TFLiteConverter.from_keras_model(k_model)%3CBR%20%2F%3Econverter.target_spec.supported_ops%3D%20%5B%3CBR%20%2F%3Etf.lite.OpsSet.TFLITE_BUILTINS%E3%80%81%3CBR%20%2F%3Etf.lite.OpsSet.TFLITE_BUILTINS_INT8%E3%80%81%3CBR%20%2F%3E%5D%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF.%E6%9C%80%E9%81%A9%E5%8C%96%3D%20%5Btf.lite.Optimize.DEFAULT%5D%3CBR%20%2F%3Econverter.representative_dataset%3D%20tf.lite.RepresentativeDataset(%3CBR%20%2F%3EImageDataset(shuffle%20%3D%20True%E3%80%81limit%20%3D%20200%E3%80%81channel_first%20%3D%20False%E3%80%81input_name%3D%22input_1%22).generator%3CBR%20%2F%3E)%3CBR%20%2F%3Econverter.target_spec.supported_ops%3D%20%5Btf.lite.OpsSet.TFLITE_BUILTINS_INT8%5D%3CBR%20%2F%3Econverter.inference_input_type%3D%20tf.int8%3CBR%20%2F%3Econverter.inference_output_type%3D%20tf.int8%3CBR%20%2F%3Etflite_model%20%3D%20converter.convert()%3CBR%20%2F%3Eopen(path_tflite%2C%20%22wb%22)%20%E3%82%92%20f%20%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Ef.write(tflite_model)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EVx%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20allowed_cache_mode%20%3CSPAN%3E%E3%81%AB%E8%A8%AD%E5%AE%9A%20%3C%2FSPAN%3E%3CSPAN%3E0.%3CBR%20%2F%3E%3C%2FSPAN%3EVx%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20device%20num%20%3CSPAN%3E%E3%82%92%20%3C%2FSPAN%3E%3CSPAN%3E0.%3CBR%20%2F%3E%3C%2FSPAN%3EVx%20delegate%3A%20allowed_builtin_code%20%3CSPAN%3E%E3%81%AB%E8%A8%AD%E5%AE%9A%20%3C%2FSPAN%3E%3CSPAN%3E0.%3CBR%20%2F%3E%3C%2FSPAN%3EVx%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20error_during_init%20%3CSPAN%3E%E3%81%AB%E8%A8%AD%E5%AE%9A%20%3C%2FSPAN%3E%3CSPAN%3E0.%3CBR%20%2F%3E%3C%2FSPAN%3EVx%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20error_during_prepare%20%E3%81%AB%3CSPAN%3E%E8%A8%AD%E5%AE%9A%20%3C%2FSPAN%3E%3CSPAN%3E0.%3CBR%20%2F%3E%3C%2FSPAN%3EVx%20%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%3A%20error_during_invoke%20%3CSPAN%3E%E3%81%AB%E8%A8%AD%E5%AE%9A%20%3C%2FSPAN%3E%3CSPAN%3E0.%3CBR%20%2F%3E%3C%2FSPAN%3E%E5%85%A5%E5%8A%9B%3A%20serving_default_input_1%3A%3CSPAN%3E0%3C%2FSPAN%3E%E5%BD%A2%E7%8A%B6%3A%20%3CSPAN%3E%5B%20%3C%2FSPAN%3E%3CSPAN%3E1%20112%20112%203%3C%2FSPAN%3E%3CSPAN%3E%5D%20%3C%2FSPAN%3Edtype%3A%20%26lt%3B%3CSPAN%3Eclass%20%3C%2FSPAN%3E%3CSPAN%3E'numpy.int8'%3C%2FSPAN%3E%26gt%3B%3CBR%20%2F%3EW%20%3CSPAN%3E%5B%3C%2FSPAN%3EHandleLayoutInfer%3A%3CSPAN%3E274%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3EOp%20%3CSPAN%3E162%3C%2FSPAN%3E%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E6%8E%A8%E8%AB%96%20%3CSPAN%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%E3%80%82%3CBR%20%2F%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E267%3C%2FSPAN%3E%3A%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%20%3CSPAN%3E%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%20(%3C%2FSPAN%3E%3CSPAN%3E0%2C267%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3A%20%E3%83%98%E3%83%83%E3%83%80%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20cl_viv_vx_ext.h%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E25%3C%2FSPAN%3E%3A%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%20%3C%2FSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E8%AD%98%E5%88%A5%E5%AD%90%3A'COPY'%3CBR%20%2F%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E59%3C%2FSPAN%3E%3A%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%20%3C%2FSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E8%AD%98%E5%88%A5%E5%AD%90%3A%20'COPY'%3CBR%20%2F%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E270%3C%2FSPAN%3E%3A%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%20%3A%20%E6%A7%8B%E6%96%87%E3%82%A8%E3%83%A9%E3%83%BC%20%3CSPAN%3E%E3%80%8CVXC_512Bits%E3%80%8D%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20vx%20%E3%82%B7%E3%82%A7%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%20%3CSPAN%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%20%3C%2FSPAN%3E%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82(%E3%82%A8%E3%83%A9%E3%83%BC%3AFFFFFFFF)%3CBR%20%2F%3EE%20%3CSPAN%3E%5B%3C%2FSPAN%3Ekernel%2Fvsi_nn_kernel.c%3A_gpu_register%3A%3CSPAN%3E600%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EE%20%3CSPAN%3E%5B%3C%2FSPAN%3Ekernel%2Fvsi_nn_kernel.c%3Avsi_nn_kernel_create_node%3A%3CSPAN%3E874%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%E7%99%BB%E9%8C%B2%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%ABcom.vivantecorp.extension.evis.prelu_U8U8toU8_2D%E5%A4%B1%E6%95%97%20%3CSPAN%3E%E3%81%99%E3%82%8B%20%3C%2FSPAN%3E-%3CSPAN%3E1.%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E267%3C%2FSPAN%3E%3A%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%20%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%20%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E0%2C267%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3A%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20cl_viv_vx_ext.h%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E25%3C%2FSPAN%3E%3A%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%20%3C%2FSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E8%AD%98%E5%88%A5%E5%AD%90%3A'COPY'%3CBR%20%2F%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E59%3C%2FSPAN%3E%3A%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%20%3C%2FSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E8%AD%98%E5%88%A5%E5%AD%90%3A%20'COPY'%3CBR%20%2F%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E270%3C%2FSPAN%3E%3A%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%20%3A%20%E6%A7%8B%E6%96%87%E3%82%A8%E3%83%A9%E3%83%BC%20%3CSPAN%3E%E3%80%8CVXC_512Bits%E3%80%8D%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E3%81%93%E3%82%8C%E3%81%8C%2049%20%E5%9B%9E%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%95%E3%82%8C%E3%80%81%E6%AC%A1%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20vx%20%E3%82%B7%E3%82%A7%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82(%E3%82%A8%E3%83%A9%E3%83%BC%3AFFFFFFFF)%3CBR%20%2F%3EE%20%5Bkernel%2Fvsi_nn_kernel.c%3A_gpu_register%3A600%5D%E3%83%93%E3%83%AB%E3%83%89%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EE%20%5Bkernel%2Fvsi_nn_kernel.c%3Avsi_nn_kernel_create_node%3A874%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%ABcom.vivantecorp.extension.evis.prelu_U8U8toU8_2D-1%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3FPReLU%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%AA%E3%81%AE%E3%81%AB%E3%80%81%E3%81%AA%E3%81%9C%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1848930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8MP%E3%81%A7%E3%81%AEPRELU%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%84%9F%E8%AC%9D%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1848252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8MP%E3%81%A7%E3%81%AEPRELU%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%8A%E9%80%B1%E3%82%82%E5%90%8C%E6%A7%98%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF%E3%80%81%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CSPAN%20class%3D%22%22%3Ecl_viv_vx_ext.h%3C%2FSPAN%3E%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%81%9F%E3%81%93%E3%82%8C%E3%82%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AFopencl%E3%83%AC%E3%82%B7%E3%83%94%E3%81%AB%E3%81%82%E3%81%A3%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E4%BD%95%E3%81%8B%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BFyocto%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99(%E9%95%B7%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99)%E3%81%8C%E3%80%81%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3A%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Flarrylart%2Fcodrive%2Fblob%2Fmaster%2Fhw_sampling%2Fvim3_npu%2Finclude%2Faml_sdk%2FCL%2Fcl_viv_vx_ext.h%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Flarrylart%2Fcodrive%2Fblob%2Fmaster%2Fhw_sampling%2Fvim3_npu%2Finclude%2Faml_sdk%2FCL%2Fcl_viv_vx_ext.h%20%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%A0%91%E5%BC%B5%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1848236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8MP%E3%81%A7%E3%81%AEPRELU%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3EHello%20Bio_TICFSL%2C%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EKirkstone%205.15.71_2.2.0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Ftflite-vx-delegate-imx%2Fblob%2Flf-5.15.71_2.2.0%2Fop_status.md%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Ftflite-vx-delegate-imx%2Fblob%2Flf-5.15.71_2.2.0%2Fop_status.md%3C%2FA%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1848228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8MP%E3%81%A7%E3%81%AEPRELU%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E3%81%9D%E3%82%8C%E3%81%AF%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%99%3A%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Ftflite-vx-delegate-imx%2Fblob%2Flf-5.15.5_1.0.0%2Fop_status.md%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Ftflite-vx-delegate-imx%2Fblob%2Flf-5.15.5_1.0.0%2Fop_status.md%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1848204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX8MP%E3%81%A7%E3%81%AEPRELU%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF6.6.3v%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%81%8BBSP%E3%81%A7%E3%81%99%E3%81%8B%3F%E4%BB%A5%E6%9D%A5%E3%80%81PRELU%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
