PRELU compilation error on iMX8MP
5,003 次查看
jetxeberria
I'm having issues compiling my model with PReLU activation for iMX8MP. This operation is supposed to be supported.
I'm converting and quantizing (to int8) the model from keras to tflite using quantization aware training with native tflite methods
k_model = keras.models.load_model(path_keras)
print("Converting Keras model to int8 tflite format")
converter = tf.lite.TFLiteConverter.from_keras_model(k_model)
converter.target_spec.supported_ops = [
tf.lite.OpsSet.TFLITE_BUILTINS,
tf.lite.OpsSet.TFLITE_BUILTINS_INT8,
converter.optimizations = [tf.lite.Optimize.DEFAULT]
converter.representative_dataset = tf.lite.RepresentativeDataset(
ImageDataset(shuffle=True, limit=200, channel_first=False, input_name="input_1").generator
converter.target_spec.supported_ops = [tf.lite.OpsSet.TFLITE_BUILTINS_INT8]
converter.inference_input_type = tf.int8
converter.inference_output_type = tf.int8
tflite_model = converter.convert()
with open(path_tflite, "wb") as f:
f.write(tflite_model)
This is the error:
Vx delegate: allowed_cache_mode set to 0.
Vx delegate: device num set to 0.
Vx delegate: allowed_builtin_code set to 0.
Vx delegate: error_during_init set to 0.
Vx delegate: error_during_prepare set to 0.
Vx delegate: error_during_invoke set to 0.
input: serving_default_input_1:0shape: [ 1 112 112 3] dtype: <class 'numpy.int8'>
W [HandleLayoutInfer:274]Op 162: default layout inference pass.
(267:0) : error : Error(0,267) : Cannot find the header file cl_viv_vx_ext.h.
(25:0) : error : undefined identifier: 'COPY'
(59:0) : error : undefined identifier: 'COPY'
(270:0) : error : syntax error at 'VXC_512Bits'
ERROR: Failed to compile vx shader. (error: FFFFFFFF)
E [kernel/vsi_nn_kernel.c:_gpu_register:600]Build program fail.
E [kernel/vsi_nn_kernel.c:vsi_nn_kernel_create_node:874]Register client kernel com.vivantecorp.extension.evis.prelu_U8U8toU8_2D fail with -1.
This is repeated for 49 times and then this last error is shown:
Do you identify this error? PReLU is supposed to work, why am I seeing this error?
Thanks in advance
4,871 次查看
JeFi
I had an similar error this week. For me it was the missing header file cl_viv_vx_ext.h that is also missing in the error message. I think it was in the opencl recipe and the header file is only copied on the yocto image if something happens (its been too long), but what you can try: just create the header file with
https://github.com/larrylart/codrive/blob/master/hw_sampling/vim3_npu/include/aml_sdk/CL/cl_viv_vx_e...
and place it in the folder of youre executable.
Best wishes
5 回复数
4,872 次查看
JeFi
Best wishes
4,850 次查看
jorgemf
This worked. Thanks!
标记 (1)
4,880 次查看
Bio_TICFSL
Hello.
Does this happens on 6.6.3v BSP? since is the first one that support PRELU.
4,873 次查看
jetxeberria
Hello Bio_TICFSL,
Thanks for your response.
We're using Kirkstone 5.15.71_2.2.0. Docs say it's supported: https://github.com/nxp-imx/tflite-vx-delegate-imx/blob/lf-5.15.71_2.2.0/op_status.md
4,877 次查看
jorgemf
it should be supported, at least it is state int he docs: https://github.com/nxp-imx/tflite-vx-delegate-imx/blob/lf-5.15.5_1.0.0/op_status.md
%3CLINGO-SUB%20id%3D%22lingo-sub-1847024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX8MP%20%E4%B8%8A%E7%9A%84%20PRELU%20%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1847024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E4%B8%BA%20iMX8MP%20%E7%BC%96%E8%AF%91%E5%B8%A6%E6%9C%89%20PReLU%20%E6%BF%80%E6%B4%BB%E7%9A%84%E6%A8%A1%E5%9E%8B%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%E6%AD%A4%E9%A1%B9%E6%93%8D%E4%BD%9C%E5%BA%94%E8%AF%A5%E5%BE%97%E5%88%B0%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%8E%9F%E7%94%9F%20tflite%20%E6%96%B9%E6%B3%95%E8%BF%9B%E8%A1%8C%E9%87%8F%E5%8C%96%E6%84%9F%E7%9F%A5%E8%AE%AD%E7%BB%83%EF%BC%8C%E5%B0%86%E6%A8%A1%E5%9E%8B%E4%BB%8E%20keras%20%E8%BD%AC%E6%8D%A2%E5%B9%B6%E9%87%8F%E5%8C%96%EF%BC%88%E4%B8%BA%20int8%EF%BC%89%E4%B8%BA%20tflite%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%3Ek_model%20%3D%20keras.models.load_model(path_keras)%3CBR%20%2F%3Eprint(%22%E5%B0%86%20Keras%20%E6%A8%A1%E5%9E%8B%E8%BD%AC%E6%8D%A2%E4%B8%BA%20int8%20tflite%20%E6%A0%BC%E5%BC%8F%22)%3CBR%20%2F%3E%E8%BD%AC%E6%8D%A2%E5%99%A8%20%3D%20tf.lite.TFLiteConverter.from_keras_model(k_model)%3CBR%20%2F%3E%E8%BD%AC%E6%8D%A2%E5%99%A8.target_spec.supported_ops%3D%20%5B%3CBR%20%2F%3E%20tf.lite.OpsSet.TFLITE_BUILTINS%EF%BC%8C%3CBR%20%2F%3E%20tf.lite.OpsSet.TFLITE_BUILTINS_INT8%2C%3CBR%20%2F%3E%20%5D%3CBR%20%2F%3E%E8%BD%AC%E6%8D%A2%E5%99%A8%E4%BC%98%E5%8C%96%3D%20%5Btf.lite.%E4%BC%98%E5%8C%96.%E9%BB%98%E8%AE%A4%5D%3CBR%20%2F%3E%E8%BD%AC%E6%8D%A2%E5%99%A8.representative_dataset%3D%20tf.lite.RepresentativeDataset%EF%BC%88%3CBR%20%2F%3E%20ImageDataset(shuffle%3DTrue%EF%BC%8Climit%3D200%EF%BC%8Cchannel_first%3DFalse%EF%BC%8Cinput_name%3D%22input_1%22).generator%3CBR%20%2F%3E)%3CBR%20%2F%3E%E8%BD%AC%E6%8D%A2%E5%99%A8.target_spec.supported_ops%3D%20%5Btf.lite.OpsSet.TFLITE_BUILTINS_INT8%5D%3CBR%20%2F%3E%E8%BD%AC%E6%8D%A2%E5%99%A8.inference_input_type%3D%20tf.int8%3CBR%20%2F%3E%E8%BD%AC%E6%8D%A2%E5%99%A8.%E6%8E%A8%E7%90%86%E8%BE%93%E5%87%BA%E7%B1%BB%E5%9E%8B%3D%20tf.int8%3CBR%20%2F%3Etflite_model%20%3D%20%E8%BD%AC%E6%8D%A2%E5%99%A8.convert()%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%20open(path_tflite%2C%20%22wb%22)%20%E4%BD%9C%E4%B8%BA%20f%3A%3CBR%20%2F%3E%20f.%E5%86%99%E5%85%A5%EF%BC%88tflite_model%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E8%BF%99%E6%98%AF%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EVx%20%E5%A7%94%E6%89%98%EF%BC%9Aallowed_cache_mode%3CSPAN%3E%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%E4%B8%BA%3CSPAN%3E0%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%20Vx%20%E4%BB%A3%E8%A1%A8%EF%BC%9A%E8%AE%BE%E5%A4%87%E5%8F%B7%3CSPAN%3E%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%E4%B8%BA%3CSPAN%3E0%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%20Vx%20%E5%A7%94%E6%89%98%EF%BC%9Aallowed_builtin_code%3CSPAN%3E%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%E4%B8%BA%3CSPAN%3E0%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%20Vx%20%E5%A7%94%E6%89%98%EF%BC%9Aerror_during_init%3CSPAN%3E%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%E4%B8%BA%3CSPAN%3E0%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%20Vx%20%E5%A7%94%E6%89%98%EF%BC%9Aerror_during_prepare%3CSPAN%3E%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%E4%B8%BA%3CSPAN%3E0%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%20Vx%20%E5%A7%94%E6%89%98%EF%BC%9Aerror_during_invoke%3CSPAN%3E%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%E4%B8%BA%3CSPAN%3E0%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%E8%BE%93%E5%85%A5%EF%BC%9Aserving_default_input_1%3A%20%3CSPAN%3E0%3C%2FSPAN%3E%E5%BD%A2%E7%8A%B6%EF%BC%9A%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E1%20112%20112%203%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20dtype%EF%BC%9A%26lt%3B%20%3CSPAN%3Eclass'numpy.int8%3C%2FSPAN%3E%20%3CSPAN%3E'%3C%2FSPAN%3E%20%26gt%3B%3CBR%20%2F%3EW%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20HandleLayoutInfer%3A%20%3CSPAN%3E274%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20Op%20%3CSPAN%3E162%3C%2FSPAN%3E%20%3A%20%E9%BB%98%E8%AE%A4%E5%B8%83%E5%B1%80%E6%8E%A8%E7%90%86%3CSPAN%3E%E9%80%9A%E8%BF%87%3C%2FSPAN%3E%E3%80%82%3CBR%20%2F%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E267%3C%2FSPAN%3E%20%EF%BC%9A%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%EF%BC%9A%3CSPAN%3E%E9%94%99%E8%AF%AF%3C%2FSPAN%3E%EF%BC%9A%E9%94%99%E8%AF%AF%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E0%EF%BC%8C267%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%EF%BC%9A%E6%89%BE%E4%B8%8D%E5%88%B0%E5%A4%B4%E6%96%87%E4%BB%B6%20cl_viv_vx_ext.h%E3%80%82%3CBR%20%2F%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E25%3C%2FSPAN%3E%20%EF%BC%9A%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9C%AA%E5%AE%9A%E4%B9%89%E6%A0%87%E8%AF%86%E7%AC%A6%EF%BC%9A'COPY'%3CBR%20%2F%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E59%3C%2FSPAN%3E%20%EF%BC%9A%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9C%AA%E5%AE%9A%E4%B9%89%E6%A0%87%E8%AF%86%E7%AC%A6%EF%BC%9A%E2%80%9CCOPY%E2%80%9D%3CBR%20%2F%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E270%3C%2FSPAN%3E%20%EF%BC%9A%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%20%3CSPAN%3E%E2%80%98VXC_512Bits%E2%80%99%E5%A4%84%E5%87%BA%E7%8E%B0%E8%AF%AD%E6%B3%95%E9%94%99%E8%AF%AF%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%3CSPAN%3E%E7%BC%96%E8%AF%91%3C%2FSPAN%3Evx%20%E7%9D%80%E8%89%B2%E5%99%A8%E3%80%82%EF%BC%88%E9%94%99%E8%AF%AF%EF%BC%9AFFFFFFFF%EF%BC%89%3CBR%20%2F%3E%20E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20kernel%2Fvsi_nn_kernel.c%3A_gpu_register%3A%20%3CSPAN%3E600%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%E6%9E%84%E5%BB%BA%E7%A8%8B%E5%BA%8F%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3EE%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20kernel%2Fvsi_nn_kernel.c%3Avsi_nn_kernel_create_node%3A%20%3CSPAN%3E874%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%E6%B3%A8%E5%86%8C%E5%AE%A2%E6%88%B7%E7%AB%AF%E5%86%85%E6%A0%B8%20com.vivantecorp.extension.evis.prelu_U8U8toU8_2D%E5%A4%B1%E8%B4%A5%EF%BC%8C%E7%BB%93%E6%9E%9C%3CSPAN%3E%E4%B8%BA%3C%2FSPAN%3E%3CSPAN%3E-1%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E267%3C%2FSPAN%3E%20%EF%BC%9A%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%EF%BC%9A%3CSPAN%3E%E9%94%99%E8%AF%AF%3C%2FSPAN%3E%EF%BC%9A%E9%94%99%E8%AF%AF%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E0%EF%BC%8C267%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%EF%BC%9A%E6%89%BE%E4%B8%8D%E5%88%B0%E5%A4%B4%E6%96%87%E4%BB%B6%20cl_viv_vx_ext.h%E3%80%82%3CBR%20%2F%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E25%3C%2FSPAN%3E%20%EF%BC%9A%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9C%AA%E5%AE%9A%E4%B9%89%E6%A0%87%E8%AF%86%E7%AC%A6%EF%BC%9A'COPY'%3CBR%20%2F%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E59%3C%2FSPAN%3E%20%EF%BC%9A%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9C%AA%E5%AE%9A%E4%B9%89%E6%A0%87%E8%AF%86%E7%AC%A6%EF%BC%9A%E2%80%9CCOPY%E2%80%9D%3CBR%20%2F%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E270%3C%2FSPAN%3E%20%EF%BC%9A%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%20%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%20%3CSPAN%3E%E2%80%98VXC_512Bits%E2%80%99%E5%A4%84%E5%87%BA%E7%8E%B0%E8%AF%AD%E6%B3%95%E9%94%99%E8%AF%AF%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E9%87%8D%E5%A4%8D%E6%AD%A4%E6%93%8D%E4%BD%9C%2049%20%E6%AC%A1%EF%BC%8C%E7%84%B6%E5%90%8E%E6%98%BE%E7%A4%BA%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E7%BC%96%E8%AF%91%20vx%20%E7%9D%80%E8%89%B2%E5%99%A8%E3%80%82%EF%BC%88%E9%94%99%E8%AF%AF%EF%BC%9AFFFFFFFF%EF%BC%89%3CBR%20%2F%3E%20E%20%5Bkernel%2Fvsi_nn_kernel.c%3A_gpu_register%3A600%5D%E6%9E%84%E5%BB%BA%E7%A8%8B%E5%BA%8F%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3EE%20%5Bkernel%2Fvsi_nn_kernel.c%3Avsi_nn_kernel_create_node%3A874%5D%E6%B3%A8%E5%86%8C%E5%AE%A2%E6%88%B7%E7%AB%AF%E5%86%85%E6%A0%B8%20com.vivantecorp.extension.evis.prelu_U8U8toU8_2D%E5%A4%B1%E8%B4%A5%EF%BC%8C%E7%BB%93%E6%9E%9C%E4%B8%BA%20-1%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E6%82%A8%E8%83%BD%E8%AF%86%E5%88%AB%E5%87%BA%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E5%90%97%EF%BC%9FPReLU%20%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E6%88%91%E4%BC%9A%E7%9C%8B%E5%88%B0%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9F%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E6%8F%90%E5%89%8D%E8%87%B4%E8%B0%A2%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1848930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX8MP%20%E4%B8%8A%E7%9A%84%20PRELU%20%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E6%9C%89%E6%95%88%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1848252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX8MP%20%E4%B8%8A%E7%9A%84%20PRELU%20%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E5%91%A8%E6%88%91%E5%8F%88%E7%8A%AF%E4%BA%86%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%EF%BC%8C%E8%BF%99%E6%98%AF%E7%BC%BA%E5%B0%91%E7%9A%84%E5%A4%B4%E6%96%87%E4%BB%B6%3CSPAN%20class%3D%22%22%3Ecl_viv_vx_ext.h%3C%2FSPAN%3E%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E4%B8%AD%E4%B9%9F%E7%BC%BA%E5%B0%91%E8%AF%A5%E5%86%85%E5%AE%B9%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E5%AE%83%E6%98%AF%E5%9C%A8%20opencl%20%E9%85%8D%E6%96%B9%E4%B8%AD%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%A6%82%E6%9E%9C%E5%8F%91%E7%94%9F%E6%9F%90%E4%BA%9B%E4%BA%8B%E6%83%85%EF%BC%88%E6%97%B6%E9%97%B4%E5%A4%AA%E9%95%BF%E4%BA%86%EF%BC%89%EF%BC%8C%E5%A4%B4%E6%96%87%E4%BB%B6%E5%8F%AA%E4%BC%9A%E5%A4%8D%E5%88%B6%E5%88%B0%20yocto%20%E5%9B%BE%E5%83%8F%E4%B8%8A%EF%BC%8C%E4%BD%86%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%EF%BC%9A%E5%8F%AA%E9%9C%80%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%88%9B%E5%BB%BA%E5%A4%B4%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Flarrylart%2Fcodrive%2Fblob%2Fmaster%2Fhw_sampling%2Fvim3_npu%2Finclude%2Faml_sdk%2FCL%2Fcl_viv_vx_ext.h%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Flarrylart%2Fcodrive%2Fblob%2Fmaster%2Fhw_sampling%2Fvim3_npu%2Finclude%2Faml_sdk%2FCL%2Fcl_viv_vx_ext.h%20%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%B9%B6%E5%B0%86%E5%85%B6%E6%94%BE%E5%9C%A8%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A5%BD%E7%9A%84%E7%A5%9D%E6%84%BF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1848236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX8MP%20%E4%B8%8A%E7%9A%84%20PRELU%20%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3EHello%20Bio_TICFSL%2C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20Kirkstone%205.15.71_2.2.0%E3%80%82%E6%96%87%E6%A1%A3%E8%AF%B4%E5%AE%83%E5%8F%97%E6%94%AF%E6%8C%81%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Ftflite-vx-delegate-imx%2Fblob%2Flf-5.15.71_2.2.0%2Fop_status.md%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Ftflite-vx-delegate-imx%2Fblob%2Flf-5.15.71_2.2.0%2Fop_status.md%3C%2FA%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1848228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX8MP%20%E4%B8%8A%E7%9A%84%20PRELU%20%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%AE%83%E5%BA%94%E8%AF%A5%E5%BE%97%E5%88%B0%E6%94%AF%E6%8C%81%EF%BC%8C%E8%87%B3%E5%B0%91%E5%9C%A8%E6%96%87%E6%A1%A3%E4%B8%AD%E6%98%AF%E8%BF%99%E6%A0%B7%E8%AF%B4%E6%98%8E%E7%9A%84%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Ftflite-vx-delegate-imx%2Fblob%2Flf-5.15.5_1.0.0%2Fop_status.md%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Ftflite-vx-delegate-imx%2Fblob%2Flf-5.15.5_1.0.0%2Fop_status.md%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1848204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AiMX8MP%20%E4%B8%8A%E7%9A%84%20PRELU%20%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E5%90%A6%E5%8F%91%E7%94%9F%E5%9C%A8%206.6.3vBSP%EF%BC%9F%E5%9B%A0%E4%B8%BA%E5%AE%83%E6%98%AF%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%94%AF%E6%8C%81%20PRELU%20%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E
