Override field in PLM_CTRL register
1,488 次查看
Kazuma_Sasaki
Senior Contributor I
PLM_CTRL register has three kind of override fields.
What is the difference between VALID_OVERRIDE, HSYNC_OVERRIDE and VSYNC_OVERRIDE settings?
From IMX8DXAEC.pdf (Rev.0):
Copy from linux/drivers/media/platform/imx8/mxc-mipi-csi2.c
Kazuma Sasaki.
标记 (2)
1,417 次查看
Bio_TICFSL
Hello Kazuma,
If valid_override is zero, this will override both HSYNC and VSYNC to be asserted.
If vsync_override is one, this will override VSYNC to be asserted.
If hsync_override is one, this will override HSYNC to be asserted.
1,418 次查看
Bio_TICFSL
Hello Kazuma,
1,417 次查看
Kazuma_Sasaki
Dear Bio,
I got it. Thank you so much.
Kazuma Sasaki.
