Output format of imx vpu decoder
1,910 次查看
girijapretha
I am using decode-example from libimxvpuapi package to decode h264 file.
I am not sure about the output format of the decoder. Is it YUV420 or YUV422?
If it is not YUV422, can we decode h264 file to produce YUV422(YUYV) output?
Thanks in advance
标签 (4)
1,714 次查看
joanxie
1) vpu output is yuv420
2) yes, you can decode h264 in yuv422
1,715 次查看
joanxie
1,714 次查看
shivaeruventi
Can VPU produce RGB out format instead of YUV formats?
