Openocd how to implement watchpoint in cortex_a.c ?
fatalfeel
how to implement in cortex_a.c ?
in cortex_m.h
#define DWT_COMP0    0xE0001020
#define DWT_MASK0    0xE0001024
#define DWT_FUNCTION0    0xE0001028
in cortex_m.c
for (i = 0; i < cm->dwt_num_comp; i++, comparator++)
        int j;
        comparator->dwt_comparator_address = DWT_COMP0 + 0x10 * i;
        for (j = 0; j < 3; j++, reg++)
            cortex_m_dwt_addreg(target, cache->reg_list + reg, dwt_comp + 3 * i + j);
        target_write_u32(target, comparator->dwt_comparator_address + 8, 0);
//do add watchpoint
comparator->comp = watchpoint->address;
    target_write_u32(target, comparator->dwt_comparator_address + 0, comparator->comp);
    comparator->mask = mask;
    target_write_u32(target, comparator->dwt_comparator_address + 4, comparator->mask);
    switch (watchpoint->rw)
        case WPT_READ:
            comparator->function = 5;
            break;
        case WPT_WRITE:
            comparator->function = 6;
            break;
        case WPT_ACCESS:
            comparator->function = 7;
            break;
    target_write_u32(target, comparator->dwt_comparator_address + 8, comparator->function);
in armv7a.h for cortex a8 a9
#define CPUDBG_WVR_BASE        0x180
#define CPUDBG_WCR_BASE        0x1C0
1. the address/mask/function is CPUDBG_WVR_BASE+0 / CPUDBG_WVR_BASE+4 / CPUDBG_WVR_BASE+8 ?
2. the address/mask/function is CPUDBG_WCR_BASE+0 ......+4......+8?
3. WPT_READ/WPT_WRITE/WPT_ACCESS  is 5/6/7 on cortex a8 a9?
Labels (5)
fatalfeel
ok may a little idea here
break
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0388e/Babcdabj.html
watch
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0388e/Babhjfhh.html
looks
break point reg / watch point reg
Breakpoint address mask =  Watchpoint address mask
Secure state access control = Secure state access control
Byte address select = Byte address select
sp =sp
B = E
only implement     watch point L/S -> Load store access
good~~~ will do it right~~~
