ONNX quantised Model
mahanad
How can I reduce the inference time for an onnx model..  It's taking roughly 6 seconds..
I tried to quantise the model using eiq toolkit but when I tried to load the model it's giving me the following error...
terminate called after throwing an instance of 'Ort::Exception'
  what(): Fatal error: QLinearAdd is not a registered function/op
Aborted
Thanks in advance...
mahanad
Can it be used with onnx? According to the documentation, it's only for tflite (I might be wrong)
Zhiming_Liu
You need use vx delegrate in your inference code.
Please see this guide :
https://www.nxp.com.cn/docs/en/user-guide/IMX-MACHINE-LEARNING-UG.pdf
