No Support for H.264 Encoder and MJPEG(Encoder & Decoder) in IMX multimedia Codec Library
3,094件の閲覧回数
adityanagal
Hi  ,
I am working on the IMX6 solo based platform and using IMX Multimedia Codec library (imx-codec-4.0.9) , but  it seems this library does not support H.264 encoding and MJPEG encoding & decoding. API document for H.264 encoding and MJPEG encoding & decoding is missing in the docs folder . Does this library supports these codecs , otherwise
how to implement encoder for H.264 and encoder and decoder for MJPEG.
Aditya Nagal
ラベル(2)
2 返答(返信)
2,775件の閲覧回数
Hi Aditya
please check attached Release Notes sect.6.5 Multimedia feature matrix, included in each bsp documentation
package from below link
http://www.nxp.com/products/microcontrollers-and-processors/arm-processors/i.mx-applications-process...
Note, not all i.MX processors have vpu so one needs to check chip full part number.
2,775件の閲覧回数
rogerio_silva
Hi Aditya,
Have you tried the VPU unit test? In images generated by NXP BSP, the VPU unit test is located at /unit_tests/mxc_vpu_test.out. It can encode and decode the formats you need. If you have problems, please let me know.
Rogerio
