Need guidance: YOLOv8 output shape mismatch on NNStreamer (i.MX8MP) + pipeline design question (mini
685件の閲覧回数
SiddavatamVishnu
HARDWARE AND SOFTWARE DETAILS
I.MX8MPlus and Linux BSP LF6.12.34_2.1.0
Goal
I’m building a command-line pipeline (no GUI) where inference, overlay, and display all run in GStreamer and NNStreamer on an i.MX8MP.
Current experiment (command line)
I tried this pipeline:
GST_DEBUG=GStreamer:4,tensor_filter:6,tensor_transform:6,tensor_decoder:7 \ gst-launch-1.0 --no-position \ v4l2src device=/dev/video4 num-buffers=200 ! \ video/x-raw,width=1920,height=1080,format=NV12,framerate=30/1 ! \ imxvideoconvert_g2d ! \ video/x-raw,width=320,height=320,format=RGBA ! \ videoconvert ! \ video/x-raw,width=320,height=320,format=BGR ! \ tensor_converter ! \ tensor_transform mode=arithmetic option=typecast:int8,add:-128 ! \ tensor_filter framework=tensorflow-lite model=${MODEL} custom=Delegate:External,ExtDelegateLib:${VX_LIB} ! \ tensor_transform mode=arithmetic option=typecast:float32,add:128.0,mul:0.004982381127774715 ! \ tensor_transform mode=transpose option=1:0:2 ! \ tensor_decoder mode=bounding_boxes option1=yolov8 option2=${LABELS} option3=0 option4=1920:1080 option5=320:320 ! \ cairooverlay name=overlay ! \ videoconvert ! \ autovideosink
log file link LINK
Problem
My YOLOv8 TFLite model outputs (1, 7, 2100), but NNStreamer on i.MX8MP expects 7 × 2100 × 1.
I received this explanation:
The YOLOv8 TFLite model outputs (1,7,2100), but NNStreamer’s YOLOv8 decoder for i.MX8MP expects 7×2100×1. This BSP version only supports transpose on 4D tensors, so the model output needs dequantization, reshape to (1,7,2100,1), then transpose.
  • input: int8 [1, 320, 320, 3]
  • output: int8 [1, 7, 2100]
  • scale/zero point
  • output correctly contains 3 classes + 4 bbox values
Current (slow) approach
Right now the application flow is:
  1. GStreamer → BGR → OpenCV
  2. NPU inference
  3. OpenCV post-processing
  4. Back to RTSP pipeline
This causes multiple software videoconvert, and in ideal conditions we reach only ~20 FPS, although the model alone can run 60+ FPS.
Proposed new approach
I want to split the pipeline:
Path A — Inference
Convert NV12 → BGR only here
Run NNStreamer
Path B — Overlay + Display
Keep original NV12/YUY2 frames
Draw bounding boxes directly on NV12 (preferably using hardware)
→ Feed NV12 to encoder / RTSP
→ Avoid software videoconvert completely
I’d first like to prototype this using pure gst-launch, then apply the approach in Python (possibly using OpenGL for NV12 overlay).
What I need help on
  1. How to reshape/transpose (1,7,2100) TFLite output into the format required by NNStreamer’s YOLOv8 decoder on i.MX8MP
    • Any working example using only tensor_filter / transform / decoder?
    • Is there a known workaround for the 3-D output?
  2. Best practice for overlay on NV12/YUY2
    • Any NNStreamer-friendly way to draw boxes directly on NV12?
    • Recommended elements (cairooverlay on NV12? OpenGL? v4l2convert? imxvideoconvert_g2d overlays?)
  3. General advice: Is the split-pipeline (inference on BGR, overlay on NV12) a reasonable architectural direction on i.MX8MP?
580件の閲覧回数
SiddavatamVishnu
I have a Update, i have used the mode dimension change (dimchg ) in the tensor_transform element to match the expections of the tensor_decoder.
....  ! tensor_filter framework=tensorflow-lite model=../../vaishnavi/model_calibrated_int8_og_320.tflite custom=Delegate:External,ExtDelegateLib:libvx_delegate.so ! tensor_transform mode=arithmetic option=typecast:float32,add:128.0,mul:0.004982381 ! tensor_transform mode=dimchg option=0:1 ! tensor_decoder mode=bounding_boxes option1=yolov8 option2=labels_over.txt option3=0 option4=1920:1080 option5=320:320 ! ......
Thanks for the replies.
Thanks and Regards
Siddavatam Vishnu
4 返答(返信)
658件の閲覧回数
Bio_TICFSL
The issue stems from a mismatch between your YOLOv8 TFLite model output shape (1,7,2100) and the format expected by NNStreamer's YOLOv8 decoder on i.MX8MP (7×2100×1). This is happening because:
1. Your current BSP version (LF6.12.34_2.1.0) supports transpose operations only on 4D tensors
2. The model output needs reshaping and transposing to match the decoder's expectations
## Recommended Solution
For the tensor transformation, you need to apply:
1. Dequantization (if using quantized model)
2. Reshape the output from (1,7,2100) to (1,7,2100,1)
3. Transpose the tensor to the required format (7×2100×1)
## Pipeline Optimization
Your proposed architecture (splitting the pipeline) is a sound approach:
- Convert NV12 → BGR only for inference
- Keep original NV12/YUY2 frames for display/encoding
- Overlay detection results directly on NV12 using hardware acceleration
This will eliminate software videoconvert operations and achieve better performance.
## Recommended Elements for NV12 Pipeline
For drawing bounding boxes directly on NV12:
- Use `imxvideoconvert_g2d` with overlay capability
- Alternative: `cairooverlay` can work with NV12 but may require format adaptation
Example pipeline structure:
v4l2src → NV12 → tee → branch1: convert to BGR → inference → detection results
branch2: original NV12 → imxvideoconvert_g2d (with overlay) → encoder/display
This approach should significantly improve performance beyond your current ~20 FPS limit, leveraging the NPU's 60+ FPS capability by eliminating unnecessary format conversions.
655件の閲覧回数
SiddavatamVishnu
Thanks for the Quick response, I had tried to use the reshape in the tensor_transform before, but it returned an error.
root@imx8mpevk:~# export MODEL=/root/rtsp/testing1/saved_model_triding_320.tflite
root@imx8mpevk:~# export LABELS=/root/rtsp/testing1/labels.txt
root@imx8mpevk:~# gst-launch-1.0 --no-position v4l2src device=/dev/video4 ! video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 ! imxvideoconvert_g2d ! video/x-raw,width=320,height=320,format=RGBA ! videoconvert ! video/x-raw,width=320,height=320,format=BGR ! tensor_converter ! tensor_transform mode=arithmetic option=typecast:int8,add:-128 ! tensor_filter framework=tensorflow-lite model=${MODEL} ! tensor_transform mode=arithmetic option=typecast:float32,add:128.0,mul:0.004982381 ! tensor_transform mode=reshape option=1:7:2100:1 ! tensor_transform mode=transpose option=1:0:2:3 ! tensor_decoder mode=bounding_boxes option1=yolov8 option2=${LABELS} option3=0 option4=1920:1080 option5=320:320 ! cairooverlay name=overlay ! videoconvert ! autovideosink
** Message: 14:56:17.877: accl = cpu
** (gst-launch-1.0:1335): CRITICAL **: 14:56:17.931: bb_getOutCaps: assertion 'config->info.info[0].type == _NNS_FLOAT32' failed
** (gst-launch-1.0:1335): CRITICAL **: 14:56:17.935: bb_getOutCaps: assertion 'config->info.info[0].type == _NNS_FLOAT32' failed
** (gst-launch-1.0:1335): CRITICAL **: 14:56:17.938: bb_getOutCaps: assertion 'config->info.info[0].type == _NNS_FLOAT32' failed
** (gst-launch-1.0:1335): CRITICAL **: 14:56:17.939: bb_getOutCaps: assertion 'config->info.info[0].type == _NNS_FLOAT32' failed
WARNING: erroneous pipeline: could not set property "mode" in element "tensor_transform" to "reshape"
root@imx8mpevk:~#
Could you please suggest changes to the pipeline to match the expected formats and also for overlaying on the nv12.
Or do i need to downgrade or upgrade my linux bsp version to match them.
If possible please test the pipeline and provide back.
Thanks and Regards
S Vishnu
603件の閲覧回数
Bio_TICFSL
Yes, you need downgrade your linux BSP. I guess with that will work because We have not yet tested pipeline in Yolov8
581件の閲覧回数
SiddavatamVishnu
Thanks and Regards
Siddavatam Vishnu
%3CLINGO-SUB%20id%3D%22lingo-sub-2257202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%3A%20NNStreamer%20(i.MX8MP)%20%E3%81%A7%E3%81%AE%20YOLOv8%20%E5%87%BA%E5%8A%9B%E5%BD%A2%E7%8A%B6%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%20%2B%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AE%E8%B3%AA%E5%95%8F%20(%E3%83%9F%E3%83%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2257202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%3CSTRONG%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A9%B3%E7%B4%B0%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3EI.MX8MPlus%20%E3%81%8A%E3%82%88%E3%81%B3%20Linux%20BSP%20LF6.12.34_2.1.0%3C%2FP%3E%3CBR%20%2F%3E%3CH2%20id%3D%22toc-hId--495505486%22%20id%3D%22toc-hId--495476464%22%20id%3D%22toc-hId--495476464%22%20id%3D%22toc-hId--495476464%22%3E%E3%82%B4%E3%83%BC%E3%83%AB%3C%2FH2%3E%3CP%3E%E7%A7%81%E3%81%AF%3CSTRONG%3E%E3%80%81%E6%8E%A8%E8%AB%96%E3%80%81%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%80%81%E8%A1%A8%E7%A4%BA%E3%81%8C%3C%2FSTRONG%3E%E3%81%99%E3%81%B9%E3%81%A6%3CSTRONG%3Ei.MX8MP%3C%2FSTRONG%3E%E4%B8%8A%E3%81%AE%20GStreamer%20%E3%81%A8%20NNStreamer%20%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%20(GUI%20%E3%81%AA%E3%81%97)%20%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1992007347%22%20id%3D%22toc-hId-1992036369%22%20id%3D%22toc-hId-1992036369%22%20id%3D%22toc-hId-1992036369%22%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E5%AE%9F%E9%A8%93%EF%BC%88%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%EF%BC%89%3C%2FH2%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3E%26nbsp%3B%3C%2FPRE%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EGST_DEBUG%3DGStreamer%3A4%E3%80%81%E3%83%86%E3%83%B3%E3%82%BD%E3%83%AB%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3A6%E3%80%81%E3%83%86%E3%83%B3%E3%82%BD%E3%83%AB%E5%A4%89%E6%8F%9B%3A6%E3%80%81%E3%83%86%E3%83%B3%E3%82%BD%E3%83%AB%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%3A7%20%5C%20gst-launch-1.0--%E3%83%9D%E3%82%B8%E3%82%B7%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AA%E3%81%97%20%5C%20v4l2src%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3D%2Fdev%2Fvideo4%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E6%95%B0%3D200%20!%5C%20%E3%83%93%E3%83%87%E3%82%AA%2Fx-raw%E3%80%81%E5%B9%85%3D1920%E3%80%81%E9%AB%98%E3%81%95%3D1080%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3DNV12%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D30%2F1%20!%5C%20imxvideoconvert_g2d%20!%5C%20video%2Fx-raw%E3%80%81%E5%B9%85%3D320%E3%80%81%E9%AB%98%E3%81%95%3D320%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3DRGBA%20!%5C%20%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%EF%BC%81%5C%20video%2Fx-raw%E3%80%81%E5%B9%85%3D320%E3%80%81%E9%AB%98%E3%81%95%3D320%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3DBGR%20!%5C%20%E3%83%86%E3%83%B3%E3%82%BD%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%20!%5C%20tensor_transform%20%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20%E7%AE%97%E8%A1%93%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%20%E5%9E%8B%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3A%20int8%E3%80%81%E8%BF%BD%E5%8A%A0%3A%20-128%20!%5C%20tensor_filter%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%20%3D%20tensorflow-lite%20%E3%83%A2%E3%83%87%E3%83%AB%20%3D%20%3CSPAN%20class%3D%22%22%3E%24%7BMODEL%7D%3C%2FSPAN%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%3D%20Delegate%3AExternal%E3%80%81ExtDelegateLib%3A%20%3CSPAN%20class%3D%22%22%3E%24%7BVX_LIB%7D%3C%2FSPAN%3E%20!%5C%20tensor_transform%20%E3%83%A2%E3%83%BC%E3%83%89%3D%E7%AE%97%E8%A1%93%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3D%E5%9E%8B%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3Afloat32%E3%80%81%E5%8A%A0%E7%AE%97%3A128.0%E3%80%81%E4%B9%97%E7%AE%97%3A0.004982381127774715!%5C%20tensor_transform%20%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20%E8%BB%A2%E7%BD%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%201%3A0%3A2%20!%5C%20tensor_decoder%20%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20bounding_boxes%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%201%20%3D%20yolov8%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%202%20%3D%20%3CSPAN%20class%3D%22%22%3E%24%7BLABELS%7D%3C%2FSPAN%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%203%20%3D%200%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%204%20%3D%201920%3A1080%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%205%20%3D%20320%3A320%20!%5C%20cairooverlay%20name%3D%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4!%5C%20%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%EF%BC%81%5C%20%E3%82%AA%E3%83%BC%E3%83%88%E3%83%93%E3%83%87%E3%82%AA%E3%82%B7%E3%83%B3%E3%82%AF%20%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CPRE%20translate%3D%22no%22%3Elog%20file%20link%20%3CA%20title%3D%22LINK%22%20href%3D%22https%3A%2F%2Fdocs.google.com%2Fdocument%2Fd%2F12BDRLqtU40uK-Gbz039lmZXWCKbktnZPyXj5ZRzyr3w%2Fedit%3Fusp%3Dsharing%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELINK%3C%2FA%3E%26nbsp%3B%3C%2FPRE%3E%3CH2%20id%3D%22toc-hId-184552884%22%20id%3D%22toc-hId-184581906%22%20id%3D%22toc-hId-184581906%22%20id%3D%22toc-hId-184581906%22%3E%3CLI-EMOJI%20id%3D%22lia_exclamation-mark%22%20title%3D%22%3Aexclamation_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20%E5%95%8F%E9%A1%8C%3C%2FH2%3E%3CP%3E%E7%A7%81%E3%81%AEYOLOv8%20TFLite%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%EF%BC%881%E3%80%817%E3%80%812100%EF%BC%89%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81i.MX8MP%E4%B8%8A%E3%81%AENNStreamer%E3%81%AF%3CSTRONG%3E7%C3%972100%C3%971%3C%2FSTRONG%3E%E3%82%92%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%AA%AC%E6%98%8E%E3%82%92%E5%8F%97%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3EYOLOv8%20TFLite%20%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%20(1%2C7%2C2100)%20%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81NNStreamer%20%E3%81%AE%20i.MX8MP%20%E7%94%A8%E3%81%AE%20YOLOv8%20%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF%207%C3%972100%C3%971%20%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%20BSP%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%204D%20%E3%83%86%E3%83%B3%E3%82%BD%E3%83%AB%E3%81%AE%E8%BB%A2%E7%BD%AE%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E5%87%BA%E5%8A%9B%E3%81%AF%E9%80%86%E9%87%8F%E5%AD%90%E5%8C%96%E3%81%97%E3%81%A6%20(1%2C7%2C2100%2C1)%20%E3%81%AB%E5%86%8D%E5%BD%A2%E6%88%90%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E8%BB%A2%E7%BD%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3E%3CP%3E%E5%85%A5%E5%8A%9B%3A%20int8%20%5B1%2C%20320%2C%20320%2C%203%5D%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%87%BA%E5%8A%9B%3A%20int8%20%5B1%2C%207%2C%202100%5D%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%2F%E3%82%BC%E3%83%AD%E7%82%B9%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%87%BA%E5%8A%9B%E3%81%AB%E3%81%AF3%E3%81%A4%E3%81%AE%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%A84%E3%81%A4%E3%81%AEbbox%E5%80%A4%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3CH2%20id%3D%22toc-hId--1622901579%22%20id%3D%22toc-hId--1622872557%22%20id%3D%22toc-hId--1622872557%22%20id%3D%22toc-hId--1622872557%22%3E%3CLI-EMOJI%20id%3D%22lia_gear%22%20title%3D%22%3Agear%3A%22%3E%3C%2FLI-EMOJI%3E%20%E7%8F%BE%E5%9C%A8%E3%81%AE%EF%BC%88%E9%81%85%E3%81%84%EF%BC%89%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%3C%2FH2%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3EGStreamer%20%E2%86%92%20BGR%20%E2%86%92%20OpenCV%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ENPU%E6%8E%A8%E8%AB%96%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EOpenCV%20%E3%83%9D%E3%82%B9%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ERTSP%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E6%88%BB%E3%82%8B%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%3CSTRONG%3E%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%3C%2FSTRONG%3E%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E5%8D%98%E7%8B%AC%E3%81%A7%E3%81%AF%2060%20FPS%20%E4%BB%A5%E4%B8%8A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E7%90%86%E6%83%B3%E7%9A%84%E3%81%AA%E6%9D%A1%E4%BB%B6%E3%81%A7%E3%81%AF%E7%B4%84%3CSTRONG%3E20%20FPS%3C%2FSTRONG%3E%E3%81%AB%E3%81%97%E3%81%8B%E9%81%94%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CHR%20%2F%3E%3CH2%20id%3D%22toc-hId-864611254%22%20id%3D%22toc-hId-864640276%22%20id%3D%22toc-hId-864640276%22%20id%3D%22toc-hId-864640276%22%3E%3CLI-EMOJI%20id%3D%22lia_counterclockwise-arrows-button%22%20title%3D%22%3Acounterclockwise_arrows_button%3A%22%3E%3C%2FLI-EMOJI%3E%20%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%3C%2FH2%3E%3CP%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%88%86%E5%89%B2%E3%81%97%E3%81%9F%E3%81%84%3A%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1555172728%22%20id%3D%22toc-hId-1555201750%22%20id%3D%22toc-hId-1555201750%22%20id%3D%22toc-hId-1555201750%22%3E%E3%83%91%E3%82%B9A%20%E2%80%94%20%E6%8E%A8%E8%AB%96%3C%2FH3%3E%3CP%3ENV12%20%E2%86%92%20BGR%20%E5%A4%89%E6%8F%9B%E3%81%AF%E3%81%93%E3%81%93%E3%81%A0%E3%81%91%3CBR%20%2F%3ENNStreamer%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3C%2FP%3E%3CH3%20id%3D%22toc-hId--252281735%22%20id%3D%22toc-hId--252252713%22%20id%3D%22toc-hId--252252713%22%20id%3D%22toc-hId--252252713%22%3E%E3%83%91%E3%82%B9B%20-%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%20%2B%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FH3%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB%E3%81%AENV12%2FYUY2%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%92%E7%B6%AD%E6%8C%81%E3%81%99%E3%82%8B%3CBR%20%2F%3ENV12%20%E4%B8%8A%E3%81%A7%E5%A2%83%E7%95%8C%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E7%9B%B4%E6%8E%A5%E6%8F%8F%E7%94%BB%E3%81%99%E3%82%8B%EF%BC%88%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8C%E6%9C%9B%E3%81%BE%E3%81%97%E3%81%84%EF%BC%89%3C%2FP%3E%3CP%3E%E2%86%92%20NV12%E3%82%92%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%2FRTSP%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E2%86%92%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%93%E3%83%87%E3%82%AA%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E9%81%BF%E3%81%91%E3%82%8B%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E7%B4%94%E7%B2%8B%E3%81%AA%20gst-launch%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%93%E3%82%8C%E3%82%92%E3%83%97%E3%83%AD%E3%83%88%E3%82%BF%E3%82%A4%E3%83%97%E5%8C%96%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AB%20Python%20%E3%81%A7%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%20(NV12%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%81%AB%E3%81%AF%20OpenGL%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3CHR%20%2F%3E%3CH2%20id%3D%22toc-hId--262784839%22%20id%3D%22toc-hId--262755817%22%20id%3D%22toc-hId--262755817%22%20id%3D%22toc-hId--262755817%22%3E%3CLI-EMOJI%20id%3D%22lia_folded-hands%22%20title%3D%22%3Afolded_hands%3A%22%3E%3C%2FLI-EMOJI%3E%20%E5%8A%A9%E3%81%91%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%93%E3%81%A8%3C%2FH2%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E(1%2C7%2C2100)%20TFLite%E5%87%BA%E5%8A%9B%E3%82%92i.MX8MP%E4%B8%8A%E3%81%AENNStreamer%E3%81%AEYOLOv8%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E5%BD%A2%E5%BC%8F%E3%81%AB%E5%86%8D%E5%BD%A2%E6%88%90%2F%E8%BB%A2%E7%BD%AE%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3Etensor_filter%20%2F%20transform%20%2F%20decoder%20%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%AE%9F%E7%94%A8%E7%9A%84%E3%81%AA%E4%BE%8B%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E3D%20%E5%87%BA%E5%8A%9B%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E6%97%A2%E7%9F%A5%E3%81%AE%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3ENV12%2FYUY2%20%E3%81%A7%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%81%AE%E3%83%99%E3%82%B9%E3%83%88%E3%83%97%E3%83%A9%E3%82%AF%E3%83%86%E3%82%A3%E3%82%B9%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3ENNStreamer%20%E3%81%AB%E9%81%A9%E3%81%97%E3%81%9F%E3%80%81NV12%20%E4%B8%8A%E3%81%A7%E7%9B%B4%E6%8E%A5%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E6%8F%8F%E7%94%BB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E8%A6%81%E7%B4%A0%20(NV12%20%E4%B8%8A%E3%81%AE%20cairooverlay%3F)%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3GL%3Fv4l2convert%3Fimxvideoconvert_g2d%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%3F)%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%3A%3C%2FSTRONG%3E%E5%88%86%E5%89%B2%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%20(BGR%20%E3%81%A7%E3%81%AE%E6%8E%A8%E8%AB%96%E3%80%81NV12%20%E3%81%A7%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4)%20%E3%81%AF%E3%80%81i.MX8MP%20%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E5%90%88%E7%90%86%E7%9A%84%E3%81%AA%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%AE%E6%96%B9%E5%90%91%E6%80%A7%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CHR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2257202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20%E3%83%9F%E3%83%8B%20%7C%20i.MX%208M%20%E3%83%8A%E3%83%8E%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2257251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Need%20guidance%3A%20YOLOv8%20output%20shape%20mismatch%20on%20NNStreamer%20(i.MX8MP)%20%2B%20pipeline%20design%20question%20(%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2257251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%BF%85%E9%80%9F%E3%81%AA%E5%AF%BE%E5%BF%9C%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E5%89%8D%E3%80%81tensor_transform%20%E3%81%A7%20reshape%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Eroot%40imx8mpevk%3A~%23%20export%20MODEL%3D%2Froot%2Frtsp%2Ftesting1%2Fsaved_model_triding_320.tflite%3CBR%20%2F%3Eroot%40imx8mpevk%3A~%23%20export%20LABELS%3D%2Froot%2Frtsp%2Ftesting1%2Flabels.txt%3CBR%20%2F%3Eroot%40imx8mpevk%3A~%23%20gst-launch-1.0--no-position%20v4l2src%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3D%2Fdev%2Fvideo4%20!%E3%83%93%E3%83%87%E3%82%AA%2Fx-raw%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3DNV12%E3%80%81%E5%B9%85%3D1920%E3%80%81%E9%AB%98%E3%81%95%3D1080%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%3D30%2F1%20!imxvideoconvert_g2d%20!%E3%83%93%E3%83%87%E3%82%AA%2Fx-raw%E3%80%81%E5%B9%85%3D320%E3%80%81%E9%AB%98%E3%81%95%3D320%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3DRGBA!%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%EF%BC%81%E3%83%93%E3%83%87%E3%82%AA%2Fx-raw%E3%80%81%E5%B9%85%3D320%E3%80%81%E9%AB%98%E3%81%95%3D320%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3DBGR%20!%E3%83%86%E3%83%B3%E3%82%BD%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC!tensor_transform%20%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20%E7%AE%97%E8%A1%93%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%20%E5%9E%8B%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3Aint8%E3%80%81%E8%BF%BD%E5%8A%A0%3A-128%20!tensor_filter%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%20%3D%20tensorflow-lite%20%E3%83%A2%E3%83%87%E3%83%AB%20%3D%20%24%7BMODEL%7D%20!tensor_transform%20%E3%83%A2%E3%83%BC%E3%83%89%3D%E7%AE%97%E8%A1%93%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3Dtypecast%3Afloat32%E3%80%81add%3A128.0%E3%80%81mul%3A0.004982381!tensor_transform%20%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20reshape%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%201%3A7%3A2100%3A1%20!tensor_transform%20%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20%E8%BB%A2%E7%BD%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%201%3A0%3A2%3A3%20!tensor_decoder%20%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20bounding_boxes%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%201%20%3D%20yolov8%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%202%20%3D%20%24%7BLABELS%7D%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%203%20%3D%200%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%204%20%3D%201920%3A1080%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%205%20%3D%20320%3A320%20!cairooverlay%20name%3D%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4!%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%EF%BC%81%E3%82%AA%E3%83%BC%E3%83%88%E3%83%93%E3%83%87%E3%82%AA%E3%82%B7%E3%83%B3%E3%82%AF%3CBR%20%2F%3E**%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3A%2014%3A56%3A17.877%3Aaccl%20%3D%20CPU%3CBR%20%2F%3E%3CBR%20%2F%3E%20**%20(gst-launch-1.0%3A1335)%3A%E3%82%AF%E3%83%AA%E3%83%86%E3%82%A3%E3%82%AB%E3%83%AB%20**%3A%2014%3A56%3A17.931%3Abb_getOutCaps%3A%20%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20'config-%26gt%3Binfo.info%5B0%5D.type%3D%3D%20_NNS_FLOAT32'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E**%20(gst-launch-1.0%3A1335)%3A%E3%82%AF%E3%83%AA%E3%83%86%E3%82%A3%E3%82%AB%E3%83%AB%20**%3A%2014%3A56%3A17.931%3Abb_getOutCaps%3A%20%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20'config-%26gt%3Binfo.info%5B0%5D.type%3D%3D%20_NNS_FLOAT32'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E**%20(gst-launch-1.0%3A1335)%3A%E3%82%AF%E3%83%AA%E3%83%86%E3%82%A3%E3%82%AB%E3%83%AB%20**%3A%2014%3A56%3A17.931%3Abb_getOutCaps%3A%20%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20'config-%26gt%3Binfo.info%5B0%5D.type%3D%3D%20_NNS_FLOAT32'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E**%20(gst-launch-1.0%3A1335)%3A%E3%82%AF%E3%83%AA%E3%83%86%E3%82%A3%E3%82%AB%E3%83%AB**%3A%2014%3A56%3A17.935%3Abb_getOutCaps%3A%20%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20'config-%26gt%3Binfo.info%5B0%5D.type%3D%3D%20_NNS_FLOAT32'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E**%20(gst-launch-1.0%3A1335)%3A%E3%82%AF%E3%83%AA%E3%83%86%E3%82%A3%E3%82%AB%E3%83%AB**%3A%2014%3A56%3A17.938%3Abb_getOutCaps%3A%20%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20'config-%26gt%3Binfo.info%5B0%5D.type%3D%3D%20_NNS_FLOAT32'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E**%20(gst-launch-1.0%3A1335)%3A%E3%82%AF%E3%83%AA%E3%83%86%E3%82%A3%E3%82%AB%E3%83%AB%20**%3A%2014%3A56%3A17.939%3Abb_getOutCaps%3A%20%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20'config-%26gt%3Binfo.info%5B0%5D.type%3D%3D%20_NNS_FLOAT32'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%81%82%E3%82%8B%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%3A%20%E8%A6%81%E7%B4%A0%20%22tensor_transform%22%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%20%22mode%22%20%E3%82%92%20%22reshape%22%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%AB%E3%83%BC%E3%83%88%40imx8mpevk%3A~%23%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BA%88%E6%83%B3%E3%81%95%E3%82%8C%E3%82%8B%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%BE%E3%81%9F%20nv12%20%E3%81%AB%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%20Linux%20BSP%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E7%B5%90%E6%9E%9C%E3%82%92%E8%BF%94%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%84%9F%E8%AC%9D%E3%81%A8%E6%95%AC%E6%84%8F%3CBR%20%2F%3ES%20%E3%83%B4%E3%82%A3%E3%82%B7%E3%83%A5%E3%83%8C%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2257223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Need%20guidance%3A%20YOLOv8%20output%20shape%20mismatch%20on%20NNStreamer%20(i.MX8MP)%20%2B%20pipeline%20design%20question%20(%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2257223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81YOLOv8%20TFLite%20%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E5%87%BA%E5%8A%9B%E5%BD%A2%E7%8A%B6%20(1%2C7%2C2100)%20%E3%81%A8%E3%80%81i.MX8MP%20%E4%B8%8A%E3%81%AE%20NNStreamer%20%E3%81%AE%20YOLOv8%20%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%A7%E6%83%B3%E5%AE%9A%E3%81%95%E3%82%8C%E3%82%8B%E5%BD%A2%E5%BC%8F%20(7%C3%972100%C3%971)%20%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%8B%E3%82%89%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E6%AC%A1%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E8%B5%B7%E3%81%93%E3%82%8A%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%201.%E7%8F%BE%E5%9C%A8%E3%81%AEBSP%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%EF%BC%88LF6.12.34_2.1.0%EF%BC%894D%E3%83%86%E3%83%B3%E3%82%BD%E3%83%AB%E3%81%AE%E8%BB%A2%E7%BD%AE%E6%BC%94%E7%AE%97%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E2.%20%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E6%9C%9F%E5%BE%85%E3%81%AB%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%86%8D%E5%BD%A2%E6%88%90%E3%81%8A%E3%82%88%E3%81%B3%E8%BB%A2%E7%BD%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%3CBR%20%2F%3E%3CBR%20%2F%3E%23%23%20Recommended%20Solution%3CBR%20%2F%3E%3CBR%20%2F%3EFor%20the%20tensor%20transformation%2C%20you%20need%20to%20apply%3A%3CBR%20%2F%3E1.%20Dequantization%20(if%20using%20quantized%20model)%3CBR%20%2F%3E2.%20Reshape%20the%20output%20from%20(1%2C7%2C2100)%20to%20(1%2C7%2C2100%2C1)%20%3CBR%20%2F%3E3.%20Transpose%20the%20tensor%20to%20the%20required%20format%20(7%C3%972100%C3%971)%3CBR%20%2F%3E%3CBR%20%2F%3E%23%23%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%20(%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E5%88%86%E5%89%B2)%20%E3%81%AF%E9%81%A9%E5%88%87%E3%81%AA%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20-%20%E6%8E%A8%E8%AB%96%E3%81%AE%E3%81%9F%E3%82%81%E3%81%A0%E3%81%91%E3%81%ABNV12%E3%82%92BGR%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%3CBR%20%2F%3E-%20%E8%A1%A8%E7%A4%BA%2F%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AB%E5%85%83%E3%81%AENV12%2FYUY2%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%92%E4%BF%9D%E6%8C%81%E3%81%99%E3%82%8B%3CBR%20%2F%3E-%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6NV12%E4%B8%8A%E3%81%A7%E7%9B%B4%E6%8E%A5%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E6%A4%9C%E5%87%BA%E7%B5%90%E6%9E%9C%E3%82%92%E8%A1%A8%E7%A4%BA%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%82%88%E3%82%8B%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%E6%93%8D%E4%BD%9C%E3%81%8C%E4%B8%8D%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%8C%E5%90%91%E4%B8%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%23%23%20NV12%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E6%8E%A8%E5%A5%A8%E8%A6%81%E7%B4%A0%3CBR%20%2F%3E%3CBR%20%2F%3ENV12%20%E4%B8%8A%E3%81%A7%E5%A2%83%E7%95%8C%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E7%9B%B4%E6%8E%A5%E6%8F%8F%E7%94%BB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%3A%3CBR%20%2F%3E-%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E6%A9%9F%E8%83%BD%E4%BB%98%E3%81%8D%E3%81%AE%20%60imxvideoconvert_g2d%60%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3CBR%20%2F%3E-%20%E4%BB%A3%E6%9B%BF%E6%A1%88%3A%20%60cairooverlay%60%20%E3%81%AF%20NV12%20%E3%81%A7CAN%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%AE%E9%81%A9%E5%BF%9C%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E6%A7%8B%E9%80%A0%E3%81%AE%E4%BE%8B%3A%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3Ev4l2src%20%E2%86%92%20NV12%20%E2%86%92%20tee%20%E2%86%92%20branch1%3A%20BGR%E3%81%AB%E5%A4%89%E6%8F%9B%20%E2%86%92%20%E6%8E%A8%E8%AB%96%20%E2%86%92%20%E6%A4%9C%E5%87%BA%E7%B5%90%E6%9E%9C%3CBR%20%2F%3Ebranch2%3A%20%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%ABNV12%20%E2%86%92%20imxvideoconvert_g2d%20(%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E4%BB%98%E3%81%8D)%20%E2%86%92%20%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%2F%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E4%B8%8D%E8%A6%81%E3%81%AA%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E5%A4%89%E6%8F%9B%E3%82%92%E6%8E%92%E9%99%A4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%20NPU%20%E3%81%AE%2060%20FPS%20%E4%BB%A5%E4%B8%8A%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E6%B4%BB%E7%94%A8%E3%81%97%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E7%B4%84%2020%20FPS%20%E3%81%AE%E5%88%B6%E9%99%90%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%8C%E5%A4%A7%E5%B9%85%E3%81%AB%E5%90%91%E4%B8%8A%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2258239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Need%20guidance%3A%20YOLOv8%20output%20shape%20mismatch%20on%20NNStreamer%20(i.MX8MP)%20%2B%20pipeline%20design%20question%20(%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2258239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81Linux%20BSP%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82Yolov8%E3%81%A7%E3%81%AF%E3%81%BE%E3%81%A0%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%A7%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2258998%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Need%20guidance%3A%20YOLOv8%20output%20shape%20mismatch%20on%20NNStreamer%20(i.MX8MP)%20%2B%20pipeline%20design%20question%20(%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2258998%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9B%B4%E6%96%B0%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82tensor_decoder%20%E3%81%AE%E6%9C%9F%E5%BE%85%E3%81%AB%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81tensor_transform%20%E8%A6%81%E7%B4%A0%E3%81%A7%E3%83%A2%E3%83%BC%E3%83%89%E6%AC%A1%E5%85%83%E5%A4%89%E6%9B%B4%20(dimchg)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E....%20!%20tensor_filter%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%20%3D%20tensorflow-lite%20%E3%83%A2%E3%83%87%E3%83%AB%20%3D%20..%2F..%2Fvaishnavi%2Fmodel_calibrated_int8_og_320.tflite%20%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%3D%20Delegate%3AExternal%E3%80%81ExtDelegateLib%3Alibvx_delegate.so%20!tensor_transform%20%E3%83%A2%E3%83%BC%E3%83%89%3D%E7%AE%97%E8%A1%93%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3Dtypecast%3Afloat32%E3%80%81add%3A128.0%E3%80%81mul%3A0.004982381!tensor_transform%20%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20dimchg%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%200%3A1%20!tensor_decoder%20%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20bounding_boxes%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%201%20%3D%20yolov8%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%202%20%3D%20labels_over.txt%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%203%20%3D%200%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%204%20%3D%201920%3A1080%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%205%20%3D%20320%3A320%20!%E2%80%A6%E2%80%A6%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%84%9F%E8%AC%9D%E3%81%A8%E6%95%AC%E6%84%8F%3CBR%20%2F%3E%E3%82%B7%E3%83%83%E3%83%80%E3%83%B4%E3%82%A1%E3%82%BF%E3%83%A0%E3%83%BB%E3%83%B4%E3%82%A3%E3%82%B7%E3%83%A5%E3%83%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E
