Native Framebuffer Window in Android Oreo
nilesh31patel
Fresh Out Contributor
Working on IMX6 platform and want to create Native framebuffer window for my application. In case of Android Marshmallow it is possible using function call "android_createDisplaySurface()" of "android-6.0.1_r22/frameworks/native/libs/ui/FramebufferNativeWindow.cpp" .
But latest Android release of Oreo does not provide FramebufferNativeWindow support.
Is there any alternative in Oreo for this?
KarthikM10
Hello nilesh,
Did you find the solution for this problem, if you find the solution for this means please reply back.
diegoadrian
I apologize for the delay,
Unfortunately, this problem is more related to the Android Operative system, we cannot provide support about this. For that, I highly recommend you to go with Google.
Diego.
